Computers & Internet Logo
D
DaveC Posted on Sep 03, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I was using my Dell E193FP monitor OK when screen turned blue-green. Tried auto-adjust, factory preset,red preset, and user preset, but could not get white color.
Red color shows OK on main menu, but changing red value in presets has no effect on screen color.
Dennis
Level 3:
Top Expert:
  • Computers & ... Master 1,057 Answers
  • Posted on Sep 03, 2019
Dennis
Level 3:
Top Expert:
Answers
1057
Questions
Helped
440790
Points
13558
There are several possible causes and test possibilities. This Dell site will walk you through the process of determining whether you can fix the problem or not.
https://www.dell.com/support/article/us/en/04/sln130763/how-to-troubleshoot-display-or-video-issues-on-a-dell-monitor?lang=en
I have a Dell E193FP Monitor. The power light is green, but the screen is blank.
There are two cables connected at the back of the monitor. one for the power and one for the video . Make sure the one for the video is securely fitted.
Hope that helps.
Thank you.
Dennis
Lg flatron w1943tb color fades in and out to a blue green
Follow the following solutions, this should fix up your trouble
1. Turn yourmonitor on. It should be on for at least 20 minutes before you continue.
2.Press the"Auto/Select" button on the front of your computer's monitor. Thescreen will be wavy while the adjustment happens. When the screen stops beingwavy, the faded colors should no longer be visible.
Follow steps 1 and 2 if you do not have a disk for the monitor.
My 2001FP shows the contrast cotrol greyed out and the screen has very low contrast, which I need to correct. I use it with a Dell Inspion 9300. The laptop screen has excellent contrast. The 2001FP...
I have four Dell 2001FP monitors. The unavailable contrast is standard for this monitor when used with digital input (DVI). Make sure your brightness is at 100%.If you want a better result of dynamic range and color, the only effective option is color calibration. I use the inexpensive Huey Pro, available
several places, including eBay. Retail is around $100. It something one uses maybe twice a year, takes five minutes to install and use, and the results are notable. I'm a designer, and need excellent color. This is the best solution. Calibrate your laptop as well, and the color should be almost exactly the same between them.
As an alternative, you can use the color settings, select User Preset, and start with something around 40 red 43 green and 37 blue. Adjust proportionately upward until you get what you want.
Another possibility is to use a different connector cable if your laptop has that option, since your monitor an take four different input formats.
Good luck.
1helpful
Everything's Gone Green !!!
Try it in someone else's computer.
To see if it is the Monitor or the Video card...
Dell E193Fp Blue Screen
It can be due to the effect of some kind of magnetic effect.. If your monitor has the degauss feature then degauss it ONCE and see if returns to normal. Do not use degauss feature more than once in less than half an hour. It can damage your monitor.
Colors have gone wrong
There could be 3 reasons for this...
1. If color settings are changed from the computer...
try to reset to defaults
2. if colors are changed from monitor..
try to reset to factory defaults
3. If the Monitor cable is loose..
try differnt monitor if available with the same cable which is used to connect monitor and computer, or try using different cable on same monitor and computer.....
Faulty monitor
Hi bakey 55 ,
Please click on the link below check whether you have connected the monitor in the same fashion or not......
http://support.dell.com/support/edocs/monitors/E193FP/En/attach.htm
You can also run a Monitor self test if the above set-up does not resolve the issue.(refer link below)
http://support.dell.com/support/edocs/monitors/E193FP/En/trouble.htm
If the above 2 links does not help then call Dell technical support at 1-800-624-9896 TOLL FREE (USA)
Goodluck :-)
5helpful
3answers
Colors are off after auto adjust
I seem to have found the solution (and the cause, perhaps?) for this problem!
I was having the EXACT same problem with a monitor I'm repairing for a friend. The capacitors on the power supply board were blown (CapXon capacitors, who'd've guessed), which was keeping it from powering up. After replacing the capacitors, the screen worked beautifully. But it had this weird yellow tint!
The strange part was that pure colors - red, green, blue - all appeared perfectly OK on screen. Curiously, the menus would show in the proper colors, except for one: the manual color adjustment menu, which illustrated "Blue" as a sort of off-green in the icon. Auto-Adjust would always fix the colors for a split second, then go back to yellow. Reset didn't fix it. Color reset didn't either. So, exactly the same problem as above.
The solution I found was hidden within the main menu itself, a sort of "easter egg". <b>Hold the Menu button down while pressing Power, and hold it down until the screen, and menu, appear</b>. There will now be a hidden selection, "Auto Color", printed in a red-on-black font at the bottom of the menu. Use the +/- buttons to access it, and press Menu. Voila! PERFECT COLOR! Perhaps this menu was accessed by accident, and calibrated to an incorrect color key. But now my picture works great, and the setting lasts through Auto-Adjusts and Resets!
Hope this helps some people, it sure saved my ****! ;)
Bank Monitor problems
Unplug the cable from your PC, if the monitor shows a test image, the monitor is fine and the problem is with your graphic card. If you dont see nothing on-screen after unpluging the cable from the PC, then the monitor in damaged. Send it to repair.
Grand Canyon Tech
Grand Canyon Tech
