LUBE THE deck belt, this happen because the system protect the electronic system, with shut down.
2= LUBE THE ROLLERS BEARINGS TOO
3= measure the input voltage motor, if there are the motor need repair
4= measure the output voltage board, for input voltage motor, if there are NOT the boar is faulty.
see the block d
God bless you
SOURCE: SPEED ERROR ON PRECOR 927 TREADMILL
I had the speed error on my precor 9.23. When I opened it up I found that there are two little round magnets on the belt pulley with a sensor mounted nearby. This must be how the computer know the speed of the treadmill. I noticed that there were several little metal shavings stuck to the magnets. Not sure where they came from, hopefully not another problem. However, I removed the metal shavings from the magnets and everything worked fine again. If anyone else has the speed error it might be worth a look to see if its the same problem.
