Miscellaneous Logo
Albert Gorovits Posted on Sep 02, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The flow of hot water is very slow.
The flow of cold water is normal, but for hot water is very slow.
Poppa Maddo
Level 2:
Sergeant:
  • Expert 372 Answers
  • Posted on Sep 03, 2019
Poppa Maddo
Expert
Level 2:
Sergeant:
Answers
372
Questions
0
Helped
118764
Points
687
Check all outlets for blockage buildup. Shower heads especially.
Justjim
Level 1:
New Friend:
  • Contributor 28 Answers
  • Posted on Sep 02, 2019
Justjim
Contributor
Level 1:
New Friend:
Answers
28
Questions
0
Helped
13041
Points
54
Can you provide some details to go on? At a tap? At all taps? In a shower mixing valve? What?
My maytag washer model lat8006aae hot water flows in slow. I reversed water supply lines, no change, replaced water strainers and new water lines, still slow flow. supply lines, inlet water valve
It is possible the hot cold switch is flawed and stuck on mix of hot and cold I would have the inlet valve checked with a multi meter they can also check it for u at most appliance parts stores
1helpful
Hot water fills very slow(30 MIN OR MORE TO FILL) good water flow from spicket to washer, screens are clear. sewems to be something with the washer its self
Might be a bad inlet valve. To confirm, swap the hot and cold hoses to your washer so that the cold water feeds the hot water connection and the hot water feeds the cold water connection. Turn off both hot and cold water faucets. Set the washer for a warm water wash. Turn on the cold water faucet, and check the flow. Then turn off the cold water faucet, and turn on the hot water faucet and check the flow. If the cold water flow fill slowly, then the problem is with the inlet valve.
It an easy part to obtain from an appliance supply house. To install disconnect the hoses to the back of the machine, and remove the back panel to get access to the valve. Should only take a couple of minutes to remove and install. Hope this helps you.
1helpful
On our Model LAT9635AAE washing machine when cycle is on cold/cold the water fills at a very slow flow. If (while water flowing on cold) the water temp switch is switched to warm and back to cold the cold...
You have a bad fill (mix) solenoid valve. The valve in the solenoid is hanging up and by switching it back and fourth between hot and cold its just working its way to the proper position..You were on the right track.....
Slow cold water flow won't go back to full flow
I think the water inlet valve is nearly stopped up with sediment in the screen filter where the supply hose screws to the valve.Cut the water off at the hose and disconnect and look for the screen. The hot water usually doensn't do this because the water has time to settle everything out while it's in the hot water heater.
Moen Kingsley roman tub- no/slow hot water flow
sounds like you may have a little debri on hot side stem or kinked hose between valve and spout turn off water to house remove handle pull bonnet and remove stem turn water back on with stem removed see how water flow is be careful turning water on you could make a mess i am assuming the low pressure is in shower only
Water Flow
disconnect your hoses and check for pressure without connected o machine, then check with int he water inlet valce for a clogged screeen slowing the pressure
Hot water
new washer valve on washers are designed to be "energy saving" most are 70/30..on warm 70 percent cold and 30 percent hot also new temp controls will reduce temp to a "safe level" by adding cold even on hot setting the on/off of water flow is being controlled by thermal sensor in water line on valve output ..in other words it's normal
Very slow cold water flow
soundslike either your cold water supply is not turned on all the way or the inlet valve is clogged w/debris. try removing cold water hose and checkin inside the valve, sometimed youll be able to remove sediment adn debris from valve from screen, if thats not the case youll need to replace the vavle itself
Kenmore wash macine
its in your cold water line valve to the washer if it works good with hot water the valve are incoming line being blocked when you turn it on the pressure comes in fast then when pressure is gone water slows down so when its off the pressure builds back up it runs fast then slow
2helpful
Cold water will not flow into machine
either the valveis faulty or the dispenser box is blocked, remove the internal hose from the valve anf see if you have full pressure at that point if yes box is blocked. Regards Advisor
Top Miscellaneous Experts
H Smith
Level 1 Expert
Robert
vince
Are you a Miscellaneous Expert? Answer questions, earn points and help others
