hi your signal could be to strong, on the aerial cable the thin brad rap 4 strands around the center solid pin then retune in auto, if this does not work you may to manual tune it in, or get someone to check your aerial and you could try a firmware update on your tv hope it helps
Check and replace its main system control memory IC. If this IC is faulty, auto tuning will not work, or, the TV will store any received channels. If the TV do not tune into channels too, the AGC voltage to its tuner, and tuner itself should be checked.
From the main menu, select the icon that looks like a little radio To search for the next stronger signal, press and hold the up or down arrow To fine tune the frequency, briefly press the up or down arrow
From the main menu, select to enter radio mode. ā¢ The earphones cable acts as FM antenna. Manually tune a radio station While in mode, you can manually tune to a radio station: 1 To search for the next stronger signal, press and hold / . 2 To fine tune the frequency, briefly press / . Auto-tune preset radio station The auto-tune feature of GoGear Vibe helps you find radio stations and save them under the preset numbers. 1 While in mode, select [Auto tune] > [Yes]. Ā»Ā» The radio automatically tunes radio stations and saves the frequencies to presets. Ā»Ā» There are 20 presets available. Ā»Ā» To stop auto tuning, press . Ā»Ā» To exit radio, press and hold for 2 seconds. EN
Most of the sony TV's comes with an auto tuning facility and all your need is ensure that the RF inout/cable TV or antennae is plugged into before the auto tuning is activated.
The auto tuning is available inthe older models on the set and in the newer models on the remote control. Choose program menu , tuning, auto mode.
Also you can search inthe manual mode individually and preset the channels position to your convenience such as news channels together, movies together etc.
Press the [i+] button on the remote control to display the DIGITAL INFO menu. Press the BLUE button to display the MAIN MENU. Press the UP or DOWN buttons to highlight AUTO TUNING then press the OK button to display the AUTO TUNING MENU. Press the RED button to start the auto tuning process for all available digital channels. Wait for the process to complete. If toy wish to CANCEL the auto tuning process whilst it is processing then press the BLUE button at any time.
Problem solved!!
According to the Sony website I needed to get a software download in order to fix this problem. I found out how to do this from the manual and realised that the re-tune menu I was looking at was for analogue only. The pictograms onmy remote control are a blurred but the manual helpfully provided a picture showing the correct program "info" button (next to 0) which has options to look at other things, including a "detailed set up" menu on the blue tab, which provides options for software download and re-tune of digital channels.
Incidentally, I discovered that my TV model was not quite as quoted above - it is KD-28DX200U, but expect the same process works for other oldish models.
Often when using a Sky box, one doesn't use the channel tuning feature of the Polaroid HDTV. Often one connects the Sky box to a component video input, and the Sky box does the tuning.
