Try this link:
https://www.support.xerox.com/en-us/article/en/1816696
SOURCE: reset WorkCentre 24, Xerox
In menus you browse to the service tab, then serivice diagnostics. Go to NVRAM reset and perform the NVM reset.
Before you do that, print out a configuration page if you want to rememebr the network settings. It will set the IP address back to default also.
SOURCE: workcentre c2424 is showing system error 39,003.40:117010
That is a document feed or scanner fault. Often times it is simply that molex connector working loose. It is the connector mounted vertically next to the main power cord on the right rear side of the machine. That bottom screw can be dificult to tighten. What I would try first is to shut the machine off, unscrew and disconnect that conntecot totally then firmly slide it in and get both the top and bottom screwss tight. Like I said, the bottom thumb screw can be hard to tighten even with a screw driver because it is a pretty soft rubber the tighteners are made out of.
If that doesnt work. go to the back and disconnect the document feed to scanner cables and reconnect. Other than that, you pretty much have to replace the feeder/scaner assembly since very very few parts are spared for that .
SOURCE: My Xerox Workcentre-5020 machine showing
@basanta711, Press 0 for 5 seconds then press green (start) then 50, green, 20 green, 0, green then on/Off the printer........... problem is solved
SOURCE: how to change ibt belt
The error code 004-346 is an IBT home position sensor. The belt may be damaged or didn't move.
The sensor which is mounted on the frame looks at the belt to see if it made a full rotation. Perhaps the sensor is dirty or damaged. Maybe the home reflective mark is damaged.
The belt may be damaged or shredded. Find out why the old belt was damaged before you install another part!
You probably need to purchase a new IBT belt PN 802K208991. The Xerox technician has a proprietary laptop to clear the codes and calibrate the "Belt Edge." The belt is very fragile, so whoever installs it needs to be very mehtodical and careful.
These may preclude you from repairing that yourself.
Whit
Item, Inc.
SOURCE: my Workcentre 7345 has a Fault Code 012-350
Make sure the cable from the Finisher is connected to the main section of the machine.
