SOURCE: How do I charge my Air Hogs Zipper?
I took the cord and put in the slot by the power switch and made sure the Zipper's power was off.
Testimonial: "THANK YOU FOR TELLING ME THAT NOW I CAN USE IT AGAIN!"
SOURCE: HAve the motorcycle air hog
Check the motor connection, looks like the wire connected to the main motor is disconnected!
Open ur toy and check on that!
SOURCE: fully charged but wont fly
There seems to be a lot of people having the same problems with this product with no idea of how to fix it so my advice would be to go to:
www.airhogs.com/#/need_help/hawk_eye
There the company that makes the product offers troubleshooting and if it fails they offer a phone number so that you can send it away to be repaired. Either try that or take it back to the shop where you got it from and get you money back.
Hope this helps
SOURCE: my air hogs switchblade's controler
always turn the switch blade off when charging it or it wont charge it and the red light goes off to save batteries on the controller..when done right it flashes red..only when it's flashing red and green will it be charged
SOURCE: i plug air hog to mycomputer and nothing takes hours to charge
Hi, The Havoc is powered within by a small rechargeable battery and it has died. It can no longer be recharged either because of its age or has discharged from sitting - not being used. If you carefully open the foam cockpit along its seam, you will find the battery is smaller than a pinky nail in size and is attached by a red and a black wire. This will be the polarity (plus or minus connection). The battery is made by a Chinese company under the name Full River and this is written on one side of the battery. On the other side is the model number such as 501417HS10C. If you want to keep flying the same Heli you will need find a local supply source. This is the stage I'm at at the moment. I did not contact Full River as yet. However I presume they sell in quantity and not by the piece. I will be checking locally for a source such as Eliminator RC. If you find a battery or a suitable replacement you will need to connect the proper coloured wires together and reglue the Havoc halves back together. That's the best I can do at this time. Full River website will provide the dimensions (in millimetres - mm), voltage, weight, etc of the battery. Good luck . Should I find a sellor I will update. Good Luck and I regret I can't do more for you!
