When I receive new computers I want to use this image to deploy new computers. What is the best option to get this done?
I assume all your new computers are same containing same hardware components? if that is the case you could do normal install of Windows 10 and the other desired software first on one computer. Once complete you can create system disk image (system backup) of this computer and transfer/restore the disk image to other computers.
Another method is to clone the system disk. The cloned disk can then be installed on target computer.
There are several SW tools to do either option. Some that come to my mind are Partition Magic and Easeus Todo. In some cases HDD and SSD manufacturers provide free SW tools to create or transfer system images.
Obviously you still need to get windows 10 licenses to each computer and activate them on each new computer manually.
SOURCE: Hi, laptop will not start
Seems like your Operation System crashed. Find your reinstall CDs and reload windows.
If you find someone who can pull the hard drive and hook it to another machine and run a check disk that might save you from reloading it and losing all your data.
SOURCE: Running updated Windows XP.
This is a problem related to a Norton security software that you might have on your computer awhile , so the best way to correct the problem is to download Norton removal tool and then after that run the software and that should do it.
SOURCE: adobe shockwave flash player crashes using XP,
Here is a complete guide to fix Shockwave Flash Crash, follow the link below:
Shockwave Flash Crash Fix
What Web browser are you using? (Internet Explorer, Google Chrome, Firefox etc.)
If you are using Internet Explorer of Firefox you may want to try to uninstall and reinstall your Adobe Flashplayer.
On your keyboard hold down the windows logo and then press R.
Once the run box comes up type in appwiz.cpl
Uninstall Flashplayer
Go to www.adobe.com and then download the latest version of Flash player (make sure you choose the version for your browser and operating system)
Hope this helps!
