Washing Machines Logo
b
bobby larry Posted on Aug 26, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Model WSM2700DAWWW washer/dryer. Why isn't washer spinning correctly?
The washer has issues in spinning (look like the agitator bad (not engaging).
Abdul Rasheed
Level 3:
Master:
  • Master 567 Answers
  • Posted on May 16, 2021
Abdul Rasheed
Master
Level 3:
Master:
Answers
567
Questions
0
Helped
181893
Points
1403
Drum brake/Clutch not released. Look for actuator under drum that pulls lever on drum assembly.
David Spradling
Level 3:
Top Expert:
  • GE Master 13,524 Answers
  • Posted on Dec 14, 2020
David Spradling
GE Master
Level 3:
Top Expert:
Answers
13524
Questions
0
Helped
929455
Points
28396
Check belt if ok check under agitator for bad cogs
1 Related Answer
Anonymous
  • 3917 Answers
  • Posted on Jul 06, 2010
SOURCE: my ge wsm2700dawww stack washer will not agitate or spin
Hi
Please find the links bellow to diagnose your problem…since your problem to the washing machine can be caused due to various reasons.Please go through the article to have an in-depth knowledge to your query…
http://www.repairclinic.com/Washing-Machine-Troubleshooting#Itdoesntspin
http://www.repairclinic.com/Washing-Machine-Troubleshooting#Itdoesntagitate
http://www.geappliances.com/search/fast/infobase/10002166.htm
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Hi own a Kenmore Type 111, Model 110.25652400, Serial # CS1013360 washing machine
Those parts are very common and cheap to buy. The problem is your model number isn’t correct. Leave out you serial number and re-check the model number. When dog agits go bad, the bottom half of the agitator should still work.
2answers
Kenmore agitates doenst spin
You will have to look at the inside of the washer when in spin cycle to see what is going on. Is the spinner motor not engaging the drum? Is the spinner working at all? It sounds like the spinner isn't being moved against the drum before the spin cycle starts. Most washers use a seperate spinner motor, which is lifted off the drum by a relay and / or solenoid and if one or more of those is malfunctioning, it will cause your described problem.
Loud constant noise (metal on metal clicking / whirring / grinding) during spin cycle
renault laguna 2006 diesel. unlock code for radio... modell renrdw100-10 .
n874 security...
pls..
thanks
Wsm2700dawww dryer will spin laundry still wet
Possible that the speed is of the spin is not enough, check the belt , check for friction to the shaft in the washer.
finally check the drain valve /pump as if there is water logged on without flushing then the valve is clogged or dirty.
1helpful
2answers
Washer is not agitating in whites and slowly in colors. What and how do we troubleshoot?
1) Verify a circuit breaker isn't tripped
2) Advance the timer control dial slowly 360 degrees-
If the washer starts spinning, then we know the motor and drive belt are fine but that there is something wrong with either the timer control dial or the agitator solenoid. Call in a professional for this.
If the washer doesn't budge, then verify that the drive belt(s) is attached and not broken by removing the back panel. If the belt is broken, replace it. If it is loose, then tighten it by loosening up the bolt holding the motor and moving it on its swingarm (much like a car alternator) until there is a 1/2 to 3/4 inch deflection in the belt.
Some washers use reversing motors. It's possible the motor works on the spin cycle but not on the wash cycle. If so, call a pro.
3) Visually inspect the lid safety switch- Is it loose or cracked? If so, the washer might work intermittently, stopping at different cycles.
4) Check motor and drive belt- Remove the main access panel (usually in the back). Is the motor spinning, but the drive belt isn't? If so, then you have a drive belt problem.
2helpful
My ge wsm2700dawww stack washer will not agitate or spin
Hi
Water is not draining?
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Kenmore 70 series 110.26732503: I had a drive block go bad and replaced. Now the machine wants to agitate during the start of the spin cycle (or the brake is some how engaging). Is there some timing issue...
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.26732503
The first thing to check and make sure of is that the two tabs on top of the Drive Tube are fit into the correct slots in the Drive Block and that the "washer" that fits on top of the Drive Shaft (Two prongs) is mounted.
Replacing the Drive Block shouldn't affect any of the timing.
When we had to replace the Agitate Cams in the transmission on ours, we found that the agitator will turn when the washer goes into the spin cycle. This isn't hurting anything and apparently helps spin the fabric softener unit.
The brake only affects the tub and not the agitators.
It's possible that the Agitate Cams aren't raising the "Agitate Gear" fully above the Connecting Rack when the washer goes into drain and spin mode.
Following is the Whirlpool PDF on installation and maintenance of top load, direct drive washers. It has a very good explanation of how the transmission works when switching from agitate to spin.
It isn't too difficult to pull the cover off the transmission but it is a messy job.
1helpful
2answers
Lower washing machine function inoperative in Maytag stackable
rclasky check this one
http://www.fixya.com/support/t827165-maytag_model_lsg7806aae
Washer model PAVT244AWW agitation noise
Sounds like the motor is going bad. It will only get louder before it finally stops. There is a device that assists the agitation motion that may be bad or is going bad.
Top GE Washing Machines Experts
Virgil Watts
Steve Sweetleaf
Steve Sweetleaf
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
