SOURCE: bizhub 250 All-In-One Laser Printer: Error code C3451 wont reset using Utility key at s...
• The Fusing Roller Thermistor does not detect
the required temperature within 30 sec. after a
warmup cycle has begun; therefore, the copier
does not complete the warm-up cycle.
• The temperature of the Fusing Rollers does not
reach the required level even after the set period
of time has elapsed during a warm-up cycle.
You may have a bad fuser section. Another reset method is a small button located on the right side of the machine under on the scanner section. Locate your network port, then to the left of the port is a small cover that can be removed, behind that cover on the left is a small black button, use a paper clip or ball point pen and press the button, this will do a machine reset. When the operation panel abort starts to load hit the number 3 button, you should see a small back circle in the top right of the operation panel. This will give you the option to do a trouble reset.
If this does not work you will need a technician to come out and replace the fuser section, make sure they bring one with them so they don't have to reschedule and come back.
SOURCE: How do I remove drawers 1 and 2 from Bizhub C200 -
Pull out the trays, locate the metal tab on the copier frame that is held in with one screw. Remove the screw and angle the tray out.
SOURCE: Error Code C3451 in konica Minolta Bizhub C200.
You will need to replace the thermostat and the best solution is to call a technician.
SOURCE: HOW DO I SOLVE ERROR CODE C3451 IN KONIKA MINOLTA
You will need to replace the thermostat and the best solution is to ask a technician to do that.
SOURCE: i am facing p21 error
This is a very common probem. it needs the IBT sencor cleaned. it is super easy if you need help contact me
