I don't know. using the same liquid volume, please consider running 3 fresh cups of white vinegar through the machine without putting in a puck.. it may just be that the hot water is being directed and restricted to one side of the puck because of a build up of lime. also, your owner's manual may offer other ideas about cleaning or flushing.
SOURCE: Grind is too coarse and "pucks" are wet and fall apart.
You say " I am getting a weak brew because of not being able to adust the grind to more coarse with the adjustment knob in the bean hopper" By making it more coarse you are making it weaker. Unless you just wrote it wrong. To make it stronger you should lower the grinder number to a smaller number. Usually about 4-6. Be sure you have the grinder grinding when you move it to a lower number. The pump noise could be that in shipping your pump came loose from it's mount. Nothing you can do without sending it to a Authorized Saeco Repair shop.
SOURCE: Saeco Vienna superautomatica Machine
if you open the steamer, does it work correctly? and if u request hot water does it come out?
if not, then its the pump..
SOURCE: Saeco Vienna de luxe no coffee comes out
The brew unit is blocked, remove unit and then remove the screen located at the top, clean screen and reassemble.
SOURCE: Saeco Vienna grinds too much coffee.
Hi
If you have the Delux or Digital there are 2 knobs in the bean hopper. Turn the small knob back 1 mark and see if that will help.
SOURCE: Hello. I have a saeco vienna superautomatic
This happens due to condensation caused by steam developed at the end
of the grinding cycle. Make sure that the grinding chamber is
completely cleaned and dried before using the grinder.
