SOURCE: Samsung SGH D500 Mobile Phone PUK Number
hi
best thing is contact your network provider and ask them for a puk code which they will give you to unlock your fone .
riz.
SOURCE: 2 Problems..Sim Card Problems
Just so you know I have an unlocked Iphone..I use my Iphone with Tmobile...All i did was pop my Tmobile sim card in..I have been using it with Tmobile ever since I got my Iphone(s)...But I had a problem after I took my sim out and put ATT sim card in to try and switch my service..But thanks anyways
SOURCE: Cant get my sciphone to work
okay turn your phone off take the back off ,battery and take the sim card out now put the battery back in with out sim card .. turn on. now go open sim and close sim 2... turn off...remove back and battery put sim card in slot 1 make sure its in all the way put battery and back on ... turn the phone on... give it a few minutes it should work....
SOURCE: I was given a Samsung
Hi you can contact your provider to get unlock code for your mobile or can try from online provider..you can try superunlockcodes to get unlock code for your mobile and get it unlocked..
I'm Ben and -- hopefully -- I can provide some meaningful
assistance.
It seems that your SIM card is locked.
SIM CARD:
If you enter a wrong PIN code too many times, usually three,
your SIM will lock itself. This protects you from someone using
your personal information or making calls if your cell phone is
lost or stolen. You may see "PIN blocked" or Enter PUK code" on
your cell phone display. The PUK code stands for PIN Unblocking
Key. In the U.S., the PUK code is rarely provided when you get
your subscription.
If you do not have your PUK code, contact the Customer Care
customer again. Give them your phone number and once they
are sure it is really you, they will give you the PUK code.
You will then be asked to set a new PIN code. Once you have
your PUK be sure to keep it in a safe place.
Note that if you enter a wrong PUK 10 times in a row, the SIM
will be permanently blocked, and you'll need to purchase a new
SIM card.
