SOURCE: maytag wahser not agitating
Either your transmission is bad which might carry a 5 year warranty or your lid switch needs replacement
SOURCE: Maytag Top load FAV6800AWW won't stop filling with water
I had the same problem. The laundry room was flooded. After running the diagnostic check on in the machine it could not find the problem. Although I went to the http://www.servicematters.com/maytag_library/html/index.html website and went through the troubleshooting table and turned the cold water valve on and off, numerous time. The valve leaked intermittently which is why some people couldn't reporduce the problem. This is a $5 solenoid that was sticking and it caused me to flood my home. I'm not impressed with Maytag's (Whirlpool) engineering. The sould have a safety shutoff valve independent to the water valve that is tripped closed when the level switch is activated. This unit was manufactured in Florence. The damn Italians must have build this cold water valve after a wine break!
Pete
SOURCE: Maytag Performa top loader stopped spinning
GO TO www.repairclinic.com ENTER YOUR MODEL NUMBER AND SCROLL ALL THE WAY DOWN AND CLICK THE RED 100 THEN LOOK FOR PART NUMBER 1042142 THIS MAY BE THE PROBLEM. IT SAYS A WORN BEARING WILL CAUSE SLOW OR NO SPIN. YOU MAY HAVE NOT NOTICED SLOW SPIN TILL NOW BUT I'D SAY CHANGE THAT AND YOU SHOULD BE GOD AGAIN GOOD LUCK
SOURCE: Top loader washing machine - won't work unless I slam down the top door. Any suggestions? Thanks
I think it is in the lid switch. If the lid switch is malfunctioning on a maytag top loader it will not start washing. Probably by slamming the lid you are making the connection you need for the time being. It is located at the back underneath the lid in the middle. Follow the link and you will see and diagram and parts associated with your washer. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=A4910&productCategoryId=0153000&brandId=3048&modelName=MAYTAG-LAUNDRY&diagramPageId=00002&componentDescription=TOP COVER, CONSOLE & LID SWITCH
SOURCE: My washer fills with water and keeps filling
The problem is simple and easy to fix. Your washer has a tubing which runs from the base of the tub to the water pressure switch. It might have vibrated loose from the switch, or their can be some sediment in the tub. Blow out the tubing and reattach it securely to the switch and pump out the water in the tub. Then try it again. I wrote an article about this:
Help my washer is overflowing !!!
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
