I have a whalfardale tv starts up alright then the colour be came distorted.
Model lcd27f1080p 33"tv
2 Suggested Answers
SOURCE:
gopakumarg43
  • 76125 Answers
SOURCE: Samsung LCD TV colour distortion
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1300 posts to different brand TVs now. Pull up older posts there.
Posted on Nov 26, 2012
Why does picture have lines of different colors?
Common easy LCD TV fix: bad picture screen rainbow colors
? 4:04
https://www.youtube.com/watch?v=KWIWeESmXC0
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
LCD Display Symptoms and causes. - YouTube
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
How To Fix A Broken Flat Screen LCD LED TV With Lines or ...
Dec 11, 2015 | Sharp Televison & Video
Nov 26, 2012 | Samsung Televison & Video
Hitachi C21 model.The colours on screen have got scrambled.
It sounds like something has left a strong magnetic field on the face of the picture tube, and that's causing the colour distortion. The electron beams from the tube's colour guns are hitting the wrong spots on the face. There is a degaussing circuit in the TV that tries to neutralise such fields every time the set turns on. Sometimes electrical equipment (particularly motorised appliances like a vacuum sweeper) operating too close to the TV can leave a field too strong for the degaussing circuit to cope with. Or a failed part in the circuit may have made it inoperative.
A hand-held degaussing coil can be used to remove the field. You can purchase one online, or call a TV service technician. It used to be a standard tool to carry.
Another possibility is that the tube has been damaged. There is a very thin metal mesh screen called the shadow mask behind the face of the tube. If this mask has been warped by a strong magnetic field or a mechanical shock (if the set was dropped, for instance), you will see the same colour distortion. In this case, however, there is no repair other than tube replacement. And that is likely to cost more than a new set with parts and labour.
Jul 26, 2010 | Hitachi C21-F200 21" TV
Samsung DLP 56" tv,distorted picture
if you say that your picture gets distorted you mean like it moves to a side? do you see a black middle block?
if it's a yes?
so its probably the light engine. you need to change it!
try this link.. http://www.discount-merchant.com/1069179-HL-N5067W-p/1069179.htm
the price is more or less depends on your TV model... $279.00
Feb 02, 2010 | Samsung DLP HL-P5663W 56" TV
Distorted Colours
your graphic card is going out
Jul 11, 2009 | Microsoft Xbox 360 Console
Samsung LE26R7 4BD, approx 4 years old, colour distortions
Check all of your cables on the back of the tv and your sources such as Cable,Sat box and DVD palyer to make sure they are fully inserted into the input and output connectors. Some times Component cables will work loose and you end up with a missing color. Temprature changes can affect intermittant connections. If that does work then you have a bad Main bd.
Jul 02, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
I have a rear projection samsung tv the picture is now colour distorted how can i fix it
need the model number and also can you explain what you mean with clor distorted? Is it appearing 3D? Let me know and post the model number and I will be able to help you.
May 18, 2008 | Samsung Televison & Video
COLLOUR DISTORTED
actually your tv set was placed near object produced magnet especially speakers, used magnet, small one to de-gauss or just like cleaning the the tv screen untill impurity colors gone. need my help....dnlsabangan@yahoo.com
Feb 14, 2008 | Televison & Video
Screen colour is distorted
hi there
you may want to check the cable that connects your tv and player as this may be faulty already and start to recieve interference. try to clean the lens as well as this also give effect to the screen.
hope this helps.
Feb 12, 2008 | JVC TH-V70 System
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
Ekse
