Question about MTX Car Audio & Video
Where can i get a Manual for a mtx 600 watt terminator amplifier its a tna251
  • 3 Answers
Try eBay Often available there from private sellers
Posted on Aug 25, 2019
SOURCE:
  • 5 Answers
SOURCE: 600 watt 2 channel power acoustik sterling amp
On your amp, there should be a switch (on the side probably) that has "LP", "HP", and "FULL" or "OFF". This is a switch for the low pass/high pass filter. Switch it to "LP" as this will allow only low frequencies to go to your subs, what you want. If you don't have that switch, go to an audio store or online audio supplier and get either a low pass filter, band pass filter, or a cross-over, and follow the wiring diagram that comes with it to filter out the high frequencies before they get to your subs.
Posted on Oct 09, 2007
  • 56 Answers
SOURCE: What fuse do I use for a 600 watt car amplifier
956
You will need a 6 Gauge wiring kit with a 50amp fuse to the battery. You can verify this by looking at the kits being sold on the internet for 600 Watt car amps.
Posted on Apr 18, 2009
  • 113 Answers
SOURCE: Need a replacement ground terminal
when you do find a replacement use Kapton tape to reduce the heat on the parts use around component and around surrounding area except the place to be soldered
Posted on Jul 05, 2009
craigperry23
  • 185 Answers
SOURCE: i have a boss rt645
That all depends on the wattage of the subs. also the independance of the subs. If your amp is 1400 watt, maximum you want is 2 600watt subs. if your subs are higher you will blow your amp eventually as your amp isnt powerful enough to pump out to that level.You should never have your amp fully turned up to max, 80% is perfect and will not make your amp blow. Hense why you want your subs less than the max output of your amp.
Posted on Mar 04, 2011
jacksont_199
SOURCE: MTX tna251
I have the same sub combo. The problem is the amp is underpowered for the 2 MTX 12s, get a bigger amp and you should be fine.
Posted on Feb 01, 2012
I bought a mtx terminator amp model no TNA251 600 watt and two subs installed. It works good for few days but now its not cranking up proper bass and sound. It always has three solid red lights everytime....
does it do this all the time when you turn it on? any sound at all?
provide more information, but my guess its that the amp is blown. replace it or sell it for parts.
Nov 11, 2013 | Car Audio & Video
MTX tna251
Nov 13, 2011 | MTX Car Audio & Video
What is the HLI port on the MTX tna251 amplifier?
Jul 15, 2011 | Car Audio & Video
Toxic tx 600 amplifier
You need to get another amp for your sub. I would say if you want good quality go for MTX because I have had amps from MTX and never had a problem. what you need to know is look at the fuses on the amp if there are 3 of the 25 amp fuses on there then it should push out about 750 watts but on MTX they under clock the amp so it will push about 800 at 14.4 volts for that you will need a 4 gauge wiring kit with a 60 amp fuse in the fuse link. As far as your other amp hook up the speakers and tweeters to that but be sure to tune in down and you would need a 8 gauge wiring kit. I hope this helps you.
Jul 27, 2010 | Car Audio & Video
How mant watts is the mtx 4002
my guess is that it would be a 400 watt 2 channel wich means 200 watts per channel or you could prob bridge it to make a full 400 watts to one channel
Nov 30, 2009 | MTX 4002 Car Audio Amplifier
How many watts is the mtx 4002
I ASSUME YOU HAVE THE TC4002:
100 WATTS X2 @ 4 OHMS.
200 WATTS X2 @ 2 OHMS
400 WATTS X1 @ 4 OHMS BRIDGED.
LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
Will a 300 rms amp power a cerwin vega vmax 124?
Hello dustin_stewa,
300 watts RMS is a little on the low side, but it'll power the sub. The sub is rated for 500 watts RMS.
If you haven't already purchased the amp, I'd recommend considering one with a little more output, perhaps in the range of 400-600 watts RMS.
Hope this helps.
Oct 19, 2009 | MTX X Thunder 300XD Car Amp
Car electronics
Mke Sure The Wires R Tightly Grounded And The Use A Higher Fuse
May 28, 2009 | MTX Audio TC6004 Multi-Channel Amp - 300W...
Car Audio & Video Logo
29 people viewed this question
Top MTX Car Audio & Video Experts
Professor_V
Professor_V
Mike Duncan
Mike Duncan
Philip Armitage
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
