What can I do when my fire stick keeps freezing
    Habit-Forming:
    New Friend:
  • 123 Answers
Most likely a slow internet connection. Check your speed with an app called Speedtest or equivalent.
Posted on Sep 02, 2019
SOURCE:
Fire stick 2 keeps buffering and freezing. Have WiFi. Network says signal is very good. How can I stop if buffering. please help. It's annoying.
You need to see what the wireless router says about the channel congestion. Not necessarily the signal strength. The firestick finds the router and connects to it by matching its channel. So in essence you have everything on the one channel. IF you have neighbors that are on the channel then it is very congested. There is no way to change the channel from the firestick side.
Jul 29, 2018 | Televison & Video
Fire stick is frozen
A number of scenarios may yield a frozen fire stick. And just what screen is visible during the freeze is sometimes relevant. Other than a reset procedure, you can also consider the scenarios mentioned on the following page:
Solved Amazon Fire Stick Black Screen Frozen updated 2018
Here is a discussion of the reset process:
How to Reset Your Amazon Fire TV
This generally involves pressing select and start simultaneously and after a restart, unplugging and re-pluging the power cable after a brief delay.
Jun 05, 2018 | Televison & Video
How do I stop the fire stick from locking up when watch a program?
If You are powering the stick from the USB port on TV, You need to plug the power to stick from the wall plugin using adapter instead of TV's USB port. The port in most cases does not have enough power to run the stick! This will cause the stick to stop performing restart or freeze up!
Jul 13, 2017 | Televison & Video
FIRE STICK FREEZE UP WHEN WATCH A PROGRAM
If You have the power side of stick plugged into a USB port on the tv, unplug it from TV and use a wall plug adapter to power the stick! Sometimes the TV USB does don't send enough juice to the stick to give it the power it needs, which will freeze up the stick! If this is the problem, and a fix please give me a point for helping Ya! Thanks!
My fire stick remote won't navigate all directions and keeps telling that the remote is "not clickable" . Had same issue using fire stick remote application on my phone.
Your remote might be in voice mode. To take it out of voice mode press the "Menu" and "Back" buttons simultaneously. This should make it clickable.
Apr 07, 2017 | Amazon Fire TV Stick
My fire stick keeps configuring when it's finished it will show fire stick then reconfigure again repeats again
Have you tried live chat with Amazon?
Have you tried Amazon Customer Service?
888-280-3321
If you contact Amazon and explain the problems you are having one of their customer service experts would be happy to help you.
Apr 03, 2017 | Amazon Fire TV Stick
My amazon fire stick remote keeps freezing up
hi check whether your internet is fast else deleted some file for internal storage device.
Mar 04, 2017 | Amazon Fire TV Stick
When im watching my fire tv stick it keeps flashing onto a blue screen then flashing back to what im watching how do i fix this
It just does this with the fire stick, regular TV is ok? If that is the case the fire stick is most likely defective.
Jan 10, 2017 | Amazon Fire TV Stick
Problem with getting tv to fire up, takes about 20 minutes of pushing power button to start.
Recent Fire TV software updates causing blank screen issues
www.aftvnews.com/recent-fire-tv-software-updates-causing-blank-screen...
Aug 17, 2015 - Ever since Fire TV software update 51.1.6.1 and Fire TV Stick software update ... update, Fire TV devices now enable HDCP immediatly at boot up. ..... I'm still getting this blank screen issue on one of my TV's but not the others.
How to Get Your New Fire TV Device Up and Running - Wired
www.wired.com/2014/12/amazon-fire-tv-setup/
WiredDec 25, 2014 - Here's how to take that new Fire TV device from zero to streaming in five easy steps. ... How to Get Your New Fire TV Device Up and Running .... I'm not sure why this is not an issue for Chrome Stick, et. al but I invite you to ...
Report Amazon Fire TV / TV Stick Playback issues here - Plex Forums
forums.plex.tv > Google TV & Amazon Fire TV
Jan 10, 2015 - Indicate if your problem is for the Fire TV/ TV Stick or both, if the FireTV, .... when playing files back, i'm getting the same freezing issues regardless of ..... to have to refresh content about 25% of the time when I first fire up Plex.
Jan 10, 2016 | Televison & Video
Wont accept registration details
Amazon.com Help: Basic Troubleshooting for Amazon Fire TV
https://www.amazon.com/gp/help/.../display.html?...
Amazon.com, Inc.... five seconds. Or, open Settings > System > Restart from the main menu. ... Note: External storage options are not available for Fire TV Stick. First, make sure ...
Amazon.com: Customer Discussions: Connecting Fire Stick to Wifi
www.amazon.com/forum/kindle?_encoding...
Amazon.com, Inc.Dec 21, 2014 - No questions asked. .... I have the same problem because my network is considered open ... I'm trying to connect to a friends Xfinity wifi with fire tv stick, I have my laptop, Ipad & phone all working thru it but TV Stick won't. ... Mine wouldn'taccept password until I connect the HDMI extender - works fine now. Fire TV Stick keeps asking for ...
Jan 3, 2015
KIndle Fire HD won't accept ...
Nov 2, 2014
How do I re-register my new ...
Mar 11, 2014
kindle won't connect with wi-fi
May 7, 2012
More results from www.amazon.com
Dec 29, 2015 | Amazon Fire TV Stick
Televison & Video Logo
82 people viewed this question
Top Televison & Video Experts
Ekse
