Question about Krups Coffee Makers & Espresso Machines
Hi, cafe machine Krups EA8278 coffee leaking from under. How to repair this problem.Thank you
    Top Expert:
  • Krups Master
  • 53,816 Answers
Repair may consist of replacement. Leaking underneath is not a good indication.
Posted on Aug 26, 2019
SOURCE:
  • 4 Answers
SOURCE: breville ESP8XL Espresso Machine Cafe Roma leaking.. help please..
We had that happen and it was a crack in the black ring that holds the filter. Breville could not supply us with one but we found an OEM part in aluminum from http://www.vancouverwireedm.com/caferomadiyt.htm. We received it 1 week after ordering. It was pretty easy to replace. Our machine works fine now.
Posted on Sep 26, 2008
  • 3741 Answers
SOURCE: I dont have an instruction manual for a Krups coffee machine.
click on this link directly for user manual of Krupp 867 and yours is 866 but its the same.Download the complete
user guide (411 Ko)
------- This will help. Thanks please keep updated.please please do rate the solution positively .thank you for using fixya
Posted on Mar 19, 2010
mcdevito75
  • 1970 Answers
SOURCE: i need a manual for my delonghi cafe parma machine
mcdevito75 here, You may be able to get the manual online at Delonghi Caffe espresso machine.
Posted on Jun 20, 2010
SOURCE: Error code 07 on my Krups XP 7220 coffee machine
Error code 07 on my Krups XP 7220 coffee machine what to do? Nick
Posted on Oct 24, 2010
espressonist
  • 1711 Answers
SOURCE: Hi, I have a Krups
One most frequent problem with your model Krups XP2000 series is a follows.
After opening the back (yes the warranty is broken) below we have some photos to help you and here is what we found. Poor quality control there are two screws holding a hose interface to the reservoir and they are not tight or became loose since they are metal screws going into plastic that get hot and vibrates.
The fix is to tighten the screws just slightly so that you do not crack the plastic then dab them with nail polish so that they do not move. (see second photo).
Posted on Jul 11, 2011
Hello, i have a krups xp7220 and i have two problems with her.
A common place for a leak under the machine is the barista seal that goes in the bottom of the boiler around that eject rod. Barista seal part number is MS5002202, Seals on the tamping piston are MS5002040 (there can be 1 or 2 of these piston seals) If fixing the leaks does not fix error 6 then I expect it will end up being the distributor. Part number MS2A01500
Jun 17, 2017 | Krups Coffee Makers & Espresso Machines
Krups 8278. How to take apart
If it is EA8278 then tank out, bottom tray out, debris container on side out, drawer above it out. Unscrew 1 or 2 screws inside beans container, remove adjustment knob (clicks up and off) remove beans container. Undo two outer screws under front top flap and one screw at center back was hidden by beans container. The oblong full size bezel at the front of the machine clicks upwards to click out of its clips. Lift lid at the front and wriggle it about forcefully to unclip the rear catches. Undo 2 screws one each side at bottom that were exposed by front bezel removal and 2 screws exposed by tank removal. Rear and sides are one piece and slide back for removal. That's it, you're in.
Feb 04, 2017 | Krups Coffee Makers & Espresso Machines
Error code 5 on Krups ea8080
During the first few seconds of pump running there is zero water flow. Either there really is no flow at all OR the flow meter is not detecting flow for some reason.
Oct 19, 2014 | Krups Cafe Express FMA110 Coffee Maker
EA6935 krups powdered coffee inside grinder and coffee grounds noncompact
You will need to pull the grinder apart & clean it out. Most likely cause of the grinder blocking up is a leak somewhere inside the machine dampening the grounds as they exit the grinder. They bind up, won't fall out and there is your blockage. You will need to find and fix the leak, there are many, many places for the leak to be, it's a job for a Krups Service Agent. I have outer housings with cutouts in them so I can run them and look inside at the same time to find those troublesome leaks.
Feb 28, 2014 | Krups Coffee Makers & Espresso Machines
Krups xp4030 leak
Hi need more info on your leak. Dazza REPAIRER
Sep 23, 2011 | Krups XP4030 Espresso Machine
During a cleaning cycle my krupa ea8080 bean to cup machine started leaking water from underneath the machine. After trying to make a coffee once it had finished, some coffee is coming out correctly, but...
I have the same problem and have now just located where the water is coming from, it is seal within the boiler/plunger and I am now on a mission to find a service kit. It took many hours to get to this problem and unless you are feeling brave I would consider sending it off to krups!!
I will let you know my progression
Mar 26, 2011 | Krups Small Appliances Espresso Machine
My Krups iron only heats up slightly. HOw do I repair?
Your question is listed under espresso machines. Are you talking about a Krups Espresso Machine? Please clareify. Does it make Coffee and Steam?
Aug 02, 2008 | Krups Orchestro Dialog FNF2 Espresso...
Manuel for xp1500 krups combinationand coffee espresso machine
decaling is something you do with coffe machines once ina while to keep the biolers from getting busted
for manuals to krups visit this link:
http://www.krupsusa.com/Consumer+Services/Product+Support/Manuals/Use+Intructions.htm
Jul 06, 2008 | Krups XP1500 & XP1530
Coffee Makers & Espresso Machines Logo
Top Krups Coffee Makers & Espresso Machines Experts
Pierre Laplante
Ray Murphy
Marvin
Marvin
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
