What should i do if the dstv doesn't show advanced settings?
How to reset explora remote
To set the remote to mode 3: press and hold both the i and BACK buttons for 3 seconds or until you see the green light blink on 1 and 2 (below the i and BACK buttons). The DStv Explora must be set up to "listen" for the correct mode. You can do this in DStv Central. Press the DStv button
Jun 29, 2017 | Computers & Internet
My dstv says the channel number you selected is not in this viewing environment on TV ?
My dstv is showing a note The channel number you selected is not in this viewing environment
May 13, 2017 | Cell Phones
How to install prophet bushiri channel on dstv
PROPHETIC CHANNEL SETTINGS on Your DECODER(DSTV)
Step: 1 Press menu Select "Advanced Options" Select "Dish Installation" Enter the pin "9949"
Select "Network Configuration" Select "Network 2 Setup" NB: Leave "Network 1 Setup (Home)" unchanged!! Set Signal Setup to "Enabled" by selecting it, and moving left or right Set Frequency to "11170" Set Symbol Rate to "26652 Set Polarization to "Vertical" Set FEC to "3/4? Select "Accept these settings"
Step: 2 Select "Network 2 Setup" Set Signal Setup to "Enabled" Set Frequency to "12682" Set Symbol Rate to "26657 Set Polarization to "Horizontal" Set FEC to "1/2? Select "Accept these settings"
Step: 3 Select "Network 3 Setup" Set Signal Setup to "Enabled" Set Frequency to "12722" Set Symbol Rate to "26657 Set Polarization to "Vertical" Set FEC to "1/2? Select "Accept these settings"
Step: 4 "Accept these settings" to go back to the "Dish Installation" menu then Select "Scan All Networks" Your decoder will go into scanning mode and might take a while to scan all networks. Do not interrupt the process even if it seams to take longer than you expected! Once completed, your picture will return as normal.
ENJOY WATCHING PROPHETIC CHANNEL.
http://schematicscom.blogspot.com/
http://electrotechnician.blogspot.com/
Nov 19, 2016 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Ekse
