When I power up my digihome TV if last used in HDMI, I get a green screen hdmi picture. Go to any other source, then back to hdmi - all good and stays that way until powered down. Next time - green. If I power down in any other source, it is fine on power up, and switching to hdmi id fine.
SOURCE:
micromaster
  • 3614 Answers
SOURCE: PS3 been working fine over
TV Connectivity
The issue of connectivity between the PS3 and the display is very complex and depends on the type of TV (Analog, Digital or HD Ready), the maker of TV (until recently, only Toshiba TVs have component AV connections as standard in Europe, most other Euro TV sets use SCART which can not carry an HD signal) and specification of TV (the very latest HD Ready TV sets have wider connectivity options than earlier HD "capable" TVs from the same manufacturer which may have lacked HDMI), and finally the configuration of the PS3 model purchased.
Posted on Feb 18, 2008
SOURCE: Rca Big screen shut down and now no power
NO audio and no picture .... no power to on - off button. Checked outlet and it is good .... cable connection good - checked with another tv....
Posted on May 15, 2008
Russmann
  • 203 Answers
SOURCE: samsung green lines....
From past experience only two things can cause this. First is the cable going from the digital board to the DMD board. Make sure you disconnect the power, and use caution disconnecting the plug or tightening it, not to strip the plastic tension screws. Don't use power screwdriver for loosening or tightening this DVI type cable. Second is the digital board itself that can cause green interference lines in picture. For this, you may consider sending the module, which is the large shielded box where the cable screws on to back of set, out for service or rebuild. Reason being it is cheaper than buying replacement digital board. If it is the board itself, start by running a search on it by part number to see who has one. As I recall, the part number should be BP94-02084A, on your model. Good luck, Russmann.
Posted on Nov 28, 2008
Buschchris1
  • 474 Answers
SOURCE: Green/white lines when using the PS3
Sounds like the PS3 is getting interference. is there anything else close to it like a Fan thats on or do you leave a cell phone next to it, Have large speakers near it or a computer thats on while your playing?
Sometimes poor shilding on an electronic device can cause interference on something else. Check the area and see.
Is there a wirless router or adapter near it. Try removing thes items one by one and see if one of them is the culprit.
A Cheap HDMI cable may not be shielded well againt EMP pulses
Posted on Dec 02, 2008
  • 77 Answers
SOURCE: TV has viera. Used HDMI
have you tried switching the imput settings
Posted on Aug 18, 2010
Sony tv no picture on screen
Hello, You probably hit the input button by mistake. If your using cable TV your input setting will depend on how the TV is connected. If your using an HDMI cable check to see what number HDMI the cable is plugging into on the back of your tv and then set the input button to the same port number. If your tv is connected with RCA cables (red,blue,green) Then hit the input to AV.
Feb 05, 2018 | Sony Televison & Video
Monitor goes black - green light stays on
My screen is black, why do I not have a picture?
Answer Antenna is not hooked up to television.
  • Make sure that the antenna cable is correctly connected to the television. If it doesn't work there appears to be no signal.
Problem is caused by television broadcast
  1. Push 'INFO' button.
  2. If the screen shows channel number (1, 2, 3, etc) try another channel. Not all channels broadcast at all times.
  3. You may have a signal problem. Contact cable provider or local broadcaster regarding the specific channel.
Television is in EXT or SIDE mode, and there is no external source provided, so screen mute (black screen) is activated.
  1. Push NEXT SOURCE button on the remote.
  2. On the screen appears all sorces.
  3. Press the UP button to switch to the TV mode.
If you are using an accessory device (DVD, DVR, or VCR), be sure the device is on and running.
Blank screen when connecting to the accessory (DVD, STB, PC) device via HDMI to HDMI.
Answer
  • Make sure the cable is well connected .
  • To check which connection is selected, Press the i+ button on the remote control.
  1. When you see Blue mute / blank screen and the i+ display does not indicate any video resolution indication then there is no valid signal detected.
    • Make sure the HDMI output of the accessory is valid by changing the video output resolution to a resolution which the TV can handle.
  2. When you see a blank screen and the i+ display shows a video resolution indication then the connection is correct.
    • The blank screen is caused by the accessory device and not by the TV.
    • To detect and remedy the problem caused by the accessory device, check the instruction manual of this device.
  3. If the problem remains : reselect the HDMI external source input by changing to the other HDMI input and back to the connected HDMI :
    1. Press AV on the remote
    2. Press up and then ok
    3. Press AV again
    4. Press down and ok
    5. The compatibility check process between TV and accessory device will start over again.
  4. Reset (switch off and back on) the TV and also reset the accessory device.
Mar 05, 2008 | Philips 42PF9630A 42 in. Plasma Television
How do I use it as HDMI screen for my PC? How to change Channel source?
If you plug your hd cable in hdmi on pc then plug into tv hdmi you have to clone the screen in you pc settings right click any ware on the pc screen you will get the graphics card settings go to screen adjust at the bottom click clone then source on tv hdmi in there are other ways just let me know what windows you using
Aug 26, 2016 | Digihome LED19913HDR 19" LED TV 1366x768,...
When i go to hook up a hdmi cable to my philips flat screen it wont recognize that i have a hdmi plugged into it. so what could that be the tv? the hdmi works with my other tv though
This model has 4 HDMI inputs, do you get same problem in each HDMI input?
Did you checked HDMI input with any other video source like dvd player or PS3 etc instead of cable box?
Below are few helpful tips to connect HDMI input..
1. Ensure that your HDMI cable is certified.
2. Press SOURCE on the remote control to switch to another source and then switch back to the HDMI source.
3. Reset the accessory device and the TV.
• Turn on the TV
• Select the HDMI channel
• Turn on the accessory device
4. While the TV and the accessory device are powered on, unplug either end of the HDMI cable and then reinsert the cable.
Try above options and if tv still does not show picture of any video source through HDMI then it seems problem of HDMI processor located on main board, visual check is needed by qualified tech or call Philips if tv is under warranty.
Hope these info will help you.
Thanks.
Nov 26, 2010 | Philips 42PFL7403D/27 42 in. LCD TV
Not able to get picture when connected to PC via HDMI
bbutler,
Your Toshiba can handle PC screen resolution up to 1024 x 768
Lower the resolution of the PC screen to somewhere between "640 x 480" and "1024 x 768". It will work just fine.
It's not likely that there is a any physical problem with either the PC or HDTV.
1. Right-click anywhere on your desktop
2. [Properties]
3. [Settings] tab
4. Slide the "Screen Resolution" pointer to the LEFT to adjust and click on [OK]
*DONE*
Oct 16, 2009 | Toshiba 37RV525R 37 in. LCD HDTV
My JVC HD-56G786 will not work with HDMI cable. when I connect the HDMI cable I get a green screen. Any ideas would be great.
I had the same problem with my JVC projection tv. It would flash green, then go to regular picture then back to green flashes. Not sure if this is the solution you were looking for, but I was able to get a good crisp picture using composite cables instead of the HDMI cable.
Aug 26, 2009 | JVC HD-52G886 52" Rear Projection HDTV
Input 6 - HD Input - Green Screen. Audio Only. No picture.
I am having a similar problem with the inputs. I have a cable box plugged in to cable antenna, DVD to video 6 using HDMI, Mac computer plugged in to video 7 - using HDMI (TV does not recognize this) and then Nintendo Wii hooked up to Video 1. My problem is that Sony only realizes 2 additional components like the video 1 (wii) and DVD on video 6, it does not play the other components. I have to niw manually switch the cables to have them work...
Aug 04, 2009 | Sony KDS-R50XBR1 50" HDTV
Sony KDS R50XBR1 TV, LIME GREEN PIC
if all sources and hdmi cable are good--you need the hdmi input board--dont know sonys letter designation
Jul 22, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have issues with my unit. Sync problems
Are you sure it's the TV and not the video source ? Have you tried other video sources ? You can also try to switch over to component cable. The red/green/blue colored cable. You only need HDMI for blu-ray to get the 1080p. If your TV is only 1080i then you don't even need to use HDMI. Also, some sources actually look better with a component cable compared to HDMI. Give it shot.
Mar 14, 2009 | Samsung LN52A550 LCD TV
LCD TV picture is green
I just called Vizio and they said to unplug the TV, then physically hold in the power button on the TV for 2 minutes.
Nov 19, 2007 | Vizio L37 Television
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Ekse
