Hi Susan,
I work in Tree Removal professionally so I think I can answer this one.
There are several methods you can use to prevent tree roots from sprouting after the tree has been removed:
It's important to note that it may not be possible to completely prevent tree roots from sprouting after the tree has been removed. Some roots may regenerate even if you use these methods. It's always best to consult with a professional tree care service if you have concerns about tree roots on your property.
If you have any more questions, you can check out my page on Tree Removal on my website.
https://protreeworks.com.au/services/gold-coast-tree-removal/
SOURCE: mower was running hit tree root mower quit
check the key on the flywheel where it meets the crank shaft it shears when this happens very very common
SOURCE: Pull cord hard to pull since I hit tree root
see if the blade is bent the check the key under the flywheel
