Question about Sunbeam Food Mixers
The drummers are he compatible with the sunbeam mixmaster legacy edition serie heritage # 2347
2 Suggested Answers
SOURCE:
  • 102366 Answers
SOURCE: how can i get a replacement manual for the sunbeam
You can download the manual from the manufacturer's web site at
http://www.sunbeam.com/Manuals/MANUALS/002347-030-000_43_32347182.PDF
Posted on May 31, 2011
How to disassemble mixmaster heritage series model 2351
try the following sites
www.eserviceinfo.com/equipment_type/model###
www.freeproductmanual.com/manufactures_name/model###
www.info.com/manuals
www.s-manuals.com/manufactures_name/model###
at the browser type the following information
sunbeam disassemble procedures for make/model ###
you could look at www.youtube.com/disassembling mixmaster model 2351
Mar 31, 2015 | Sunbeam Food Mixers
Will not mix
if the motor isnt making a noise then it could be the brushes in the motor that are worn.. or it could be the fuze in the plug have you tried a new one in there
Apr 06, 2014 | Sunbeam 2347 MixMaster Heritage Series...
I have a Sunbeam Mixmaster 2351 Heritage Series that the speed dial control numbers fade. Sunbeam replaced my mixer but want to prevent the same problem for reoccurring, Any suggestions?
I would propose to solution to your problem,
one. Try getting some clear contact and cutting a a square or circle a little more than the size of the dial. Removed the dial if possible and later clear contact over the surface.
Two. Get some clear nail polish and cover the markings on the dial with thin coat.
Warning warning warning!!! (Test the nail polish on a surface that is not exposed, for example underneath) to make sure that the nail polish does not react with the surface of the mixer.
Regards
Trevor
Feb 15, 2012 | Sunbeam 2346 Heritage MixMaster Series...
My Sunbeam mixmaster bowl won't turn, how can I fix this?
I believe that this particular model is supposed to have the bowl mix separately. I have removed the black piece from the bottom of the larger bowl in order to allow manual spinning. If I am able to figure out how to fix the bowl spinner I will make another post.
Mar 06, 2011 | Sunbeam 2346 Heritage MixMaster Series...
How can i get a replacement manual for the sunbeam mixmaster heritage series 2347
Feb 25, 2011 | Sunbeam Heritage 2346 Stand Mixer
Vintage Sunbeam Mixmaster MXG makes a strange noise and has a burning smell when operating. Is there anyway I can fix this?
the motor is burning out at the coil you can send it into a electric motor re winder but it could be expensive look them up in your local directory
Jul 04, 2010 | Sunbeam 2346 Heritage MixMaster Series...
New mixer did not come with manual
Hi MITCH, Happy New Year! Somebody at Sunbeam must have been asleep when the mixer passed by on the production line...duh? I hate when that happens. The good news is that you can download a PDF Users Manual from the Sunbeam website. Just click on this link Heritage Series 2353 Mixmaster and look for your M-I-L’s model to about ½-way down the page. Open the file and save it to your PC.
I’m not very keen with the way Sunbeam lays out their User’s Manuals. You’ll need to do some editing and repaginating to get it into a format that your M-I-L- can use, but at least you’ll have it. You can send it to her electronically or print just the English pages and mail; your choice.
Good Luck. I hope this helps. Howard, Burke, VA
If this solution has been helpful, please rate it, thanks! - hslincoln
Jan 18, 2010 | Sunbeam 2353 Stand Mixer
Sunbeam Mixmaster Heritage Series Model 2350 speed problem
The speed control on the back is simply a variable resistance potentiometer, the same thing that controls the volume on older amplifiers. The output current to the motor is supplied by the printed circuit board in the bottom of the unit. This allows gradual increases in speed to avoid over-torquing the motor on speedup. Even the poshy-posh-posh mixers do this.
At least it still works. The most common problem is the cheap plastic drive gears that strip out with a mild cookie dough, this jams the beaters together and requires burial-at-dumpster.
Dec 14, 2008 | Sunbeam 2346 Heritage MixMaster Series...
Sunbeam mixmaster heritage series
http://www.repairclinic.comThis is a helpful website with an 800 number and they are good about helping with the fix.
You probably have to replace worn gears and or bearings.
Feb 20, 2008 | Sunbeam 2370 MixMaster Series Stand Mixer
Food Mixers Logo
Top Sunbeam Food Mixers Experts
Vincent G
Vincent G
Bruce Showalter
Jerry Greenberg
Jerry Greenberg
Are you a Sunbeam Food Mixer Expert? Answer questions, earn points and help others
