Computers & Internet Logo
Charlotte Posted on Aug 24, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My iLive platinum was connected to my Wi-Fi and was working great for over 6 months, now it’s connecting to Wi-Fi but not connecting the speaker and it’s not showing that my same Wi-Fi is unsecured. What do I do?
Jeffrey Groves
Level 3:
  • Master 573 Answers
  • Posted on Aug 27, 2019
Jeffrey Groves
Master
Level 3:
Answers
573
Questions
Helped
140537
Points
1832
Sounds like your WiFi settings got changed to unsecure or you have a neighbor with the same WiFi network ID (SSID) that is confusing your iLive platinum.
Try changing the name of your WiFi network and confirm that you have WPA2 security enabled.
5 Related Answers
Anonymous
  • 146 Answers
  • Posted on Feb 15, 2008
SOURCE: Wi-Fi Connectivity
login to http://xda-developers.com ;and this will solve the problem of your PDA
All the Best.
Was this solution helpful? Show your Appreciation by rating it:
Anonymous
  • 6 Answers
  • Posted on Jan 05, 2009
SOURCE: Unable to connect to wi-fi
I think it is saying that the wifi "card" is set so that it is not being configured by windows.
In XP
Control panel > Network connections
Under LAN or High-speed internet you will see an icon labelled wireless network connection. Right click on this and then click properties. You will see three tabs at the top
General - Wireless Networks - Advanced
Click on wireless networks
There should be a tick-box saying Use windows to configure my wireless network settings. I expect that, in your case, the box is unticked which means that the software supplied by the vendor of the wifi card is configuring the settings. I find that it is usually more reliable to let windows do it.
So tick the box and click OK. You may then have to reboot.
Anonymous
  • Posted on Feb 24, 2009
SOURCE: I cant get internet on my itouch although im connected to a wi-fi
My mp4 turns on and the screen turns blue and then it says loading.I cant get it to do anthing past now loading.How can i fix this,?i have tried everything.
Anonymous
  • Posted on Jun 17, 2009
SOURCE: I cannot make a wi-fi connection
are you that ******* stupid that you think that blackberrys have wifi you ignorant lowlife ***** you cheap ***** blackberrys do not have wi fi you better go to a low quality iphone with that **** you have been dismissed wiht your stale ***
gaganddun
Gagan Gupta
  • 114 Answers
  • Posted on Mar 15, 2011
SOURCE: I had recently purchased Samsung
Dear Meghna you have not mentioned the wifi router make and moel
no problem
for this you have to go to your router web admin to add your device as WPS client this will solve the problem
for that all the models are differently configured so you have to try playing with the settings yourself, if you jumble up the settings of you wifi router there is a reset switch in all the routers that restors your router to factory settings.
if you find my information useful dont forget to vote me with the thumbsup thankyou and take care Gagan Gupta
2answers
Amazon Alexa Dot unit won't connect to the Internet while other WiFi devices connect fine. Doing the Alexa Dot Setup doesn't help. WiFi Router Modem was changed recently.
  • Plug your Echo Dot into a power outlet.
  • Open the Alexa app.
Saving Your Wi-Fi Passwords to Amazon FAQs.
  • Optional - Connect to a public network: Enter any required information if you are connecting to a public network that requires a web browser to sign in, like a school or hotel. The information could be a pre-shared password, room number, or just a button to accept conditions for using the network. This information cannot be saved to Amazon. Contact the network owner for more information.
  • Select Connect. After your device connects to your Wi-Fi network, a confirmation message appears in the app. You're now ready to use Alexa.
  • 1helpful
    Having trouble with a wi fi connection from my cgo2 camera to my galaxy 7 phone.it will connect sometimes but not every time.anything i can do to get a reliable connection every time?
    camera distance may be too far from wi fi source ie router or access point ? possible solution use a wi fi range extender.
    Neighbours Wi Fi interfering with your WI FI . possible solution change the channel used by your wi fi from auto to channel 3 or channel 6 . This ensures channel spacing from neighbors if they are on auto as well . Setting in wi fi access point or wi fi router
    1helpful
    Cant get wi fi signal.
    Solution 1.Check wireless connection.
    The first step of diagnosis have to any other device connected to the same network, ensure the wireless connection is working fine, or verify the settings of your wireless router to correct it.
    2.Check your Keep Wi-Fi on during sleep Settings.
    Owing to Wi-Fi sleep policy your Wi-Fi connection may be going to get disconnected every now and then.
    Tweak this policy to keep your Wi-Fi connection awake.
    [Settings] >>[Wi-Fi]>>[Advanced]>> Check [Always] to keep the Wi-Fi on during sleep.
    Save changes and exit all the screens. Your Wi-Fi will never get disconnected again due to this policy.
    3.Check signal strength of wireless connection.
    The performance of a wireless network connection depends in part on signal strength.
    You have to connect the Wireless network where the signal strength is strong.
    Check Wireless network signal strength icons in notification bar.
    4.Try to turn off/on Wi-Fi on the device.
    First to turn off Wi-Fi, [Settings]>>[Wi-Fi] >>[turn Wi-Fi to off].
    And then to turn on Wi-Fi, [Settings]>>[Wi-Fi]>>[turn Wi-Fi to on].
    5.Try to forget network on the device.
    Forgetting wireless networks allow your tablet/phone to reset some settings.
    [Settings]>>[Wi-Fi]>>Press & hold your[Net Work Name(SSID)]for 2 seconds.
    >>Select[Forget Network]>>Re-Connect your wireless networks if it's disconnected.
    6.Try to reboot your device.
    7.Make sure your firmware is up-to-date.
    >>Select[Settings]>>[About tablet]>>[System Firmware Update]>>[Check Update].
    8.Try to reset your device.
    Note: once RESET was performed, all data, apps, settings and personal information will be deleted after initialization.
    Third-party programs might be the major probability of Tablet/Phone instable, suggested to have a full reset for the device if the situation persists.
    [Settings]>>[Backup&reset]>>[Factory data reset]
    9.Try to other wireless connections.
    If steps above were not able to solve internet connection problem still, please try other wireless connections if available, otherwise contact your networking provider to technical support.
    I dont have internet connection but I am charged ofnet charges and on net charges .Pl clarify
    You will incur charges if you don't have a Wi-Fi connection. Make sure your wi-fi is enabled on your phone by going to settings. Then connect to your wi-fi. If you don't have wi-fi then you will incur charges!
    Sep 13, 2014 • Cell Phones
    2answers
    My iPhone don't work with my Bluetooth speaker system
    Paired is not connected. Connecting is the next step after pairing. Then make sure that the ilive speaker is set as the dudio output device.
    Wifi will not connect
    The below info is from user manual ... downloadable version @ www.pantech.com
    Connectivity
    This chapter introduces useful tips on how to connect to the
    network available that enables applications of the phone to
    run.
    Using a Wi-Fi network
    Connecting to a Wi-Fi network
    1. Tap Settings from the applications menu.
    2. Tap Wireless & networks > Wi-Fi settings.
    3. Tap Wi-Fi to activate the technology.
    4. Select and tap a network. You should enter the password
    if the network is secured. indicates a secured Wi-Fi
    network.
    5. Tap Connect. Once the network is remembered, the phone
    will automatically connect to it when in range.
    Activating Wi-FI Connecting to a Wi-Fi
    network
    Note The icon next to each network indicates the strength of the
    signal. For example, indicates the signal is poor while indicates
    the signal is strong.
    Using the Easy Setting
    1. Tap on the top of the home screen and drag it down, or
    press n in idle mode and tap Notifications.
    2. Tap in Easy Setting. The icon turns red when the
    function is on.
    About network notifications
    You are informed by default when a Wi-Fi network is available
    around you. The message in the status bar indicates a
    network is available. Tap Network notification in the Wi-Fi
    settings if you do not want to be informed the availability of the
    network.
    Setting Wi-Fi networks
    4. Tap Network notification if you want to know an open
    network available.
    5. Tap Automatic connection if you want the phone to
    connect to Wi-Fi network automatically.
    6. Tap WPS button connection if you want to establish a
    new wireless connection using the Wi-Fi Protected Setup
    (WPS). You should press WPS button on your Wi-Fi access
    point within two minutes.
    Searching for Wi-Fi networks
    Low connectivity for d link 524 airplus g
    Things That Affect Wireless Router Signals1. Many wireless routers are using the same wirelesschannel. Many manufacturers choose channel 6 as the default.2. Analogue video senders used to send audio and video toother TVs in the home.3. Microwave ovens emit interference in the 2.4GHz band.4. Wireless speakers and console controllers can causeinterference with the wireless router.5. Bluetooth devices, newer Bluetooth devices can jump todifferent frequencies if there is a connection problem.6. Power cables located near the wireless router can causedrop outs and speed reduction.7. Fish tanks will cause massive Wi-Fi shadow on the otherside of the tank from the wireless router. 8. Depending upon the location of large mirrors will reflectwireless signal away your computer.9. Building materials will block wireless signals such asplasterboards with metal foil, reinforced concrete walls and floors. Alsoobjects near the wireless router such as metal filing cabinets and otherelectrical appliances. 10. Blinking Christmas lights can reduce Wi-Fi performanceby 25% when it is close to the wireless router.
    Internet connection does not work on my phone LG cookie. teach me how to open it.
    jus b clear whether ur cells internet connection is not workin( gprs ) or wi-fi.... if its wi-fi, then u have to save ur wi-fi settins b4 usin it... not lyk laptops cells dnt get settins automatically... u cant use unknown wi-fi without knowin its settins........
    I can't get my Mystery Gift on my Pokemon Platinum. I don't know what is a VIA NINTENDO WFC. I try it then it said ERROR CODE: 51099. I don't know why.
    WFC: Wi-Fi Connection. Its your internet if its not Wi-Fi then you wont get the Mystery Gift Pokemons or Event. Ask your parents if your Internet is Wi-Fi
    Top The Computers & Internet Experts
    Alexander
    nexrad_chris
    vince
    Are you a The Computer and Internet Expert? Answer questions, earn points and help others
