SOURCE: need to locate the neutral safety switch on a 2005 chevy equinox
The park / neutral switch is on top of the transmission. It has a 2 wire connector. the wire colors are pink and orange/black. Tech jk
SOURCE: neutral safety switch
It is located on the side of the transmission, follow the shift cable down to it you will recognize it because it has a electrical wire comming off it and either a shift lever or shift cable going to it.
most gm nuet safety is yellow and purple .....out of ignition switch is a big yellow wire that is crank out and input to nuet saf switch......out of nuet switch is color purple that goes strieght to start selenoid.....purple wire also goes to the crank fuse 5amp.. in the fuse box under dash... this fuse goes to the pcm main computer.. same for auto and clutch
SOURCE: Looking for the neutral safety switch
Neutral Safety/Back-up Light Switch
This is a combination switch which controls both Neutral Safety and Back-up lamp circuits.
C6 Transmission
C6 neutral start switch
AOD Transmission
Removing the AOD neutral start switch
4R70W Transmission
Removing the Manual Lever Position (MLP) sensor
As of 1994, the neutral safety switch is referred to as a Manual Lever Position Sensor (MLP).
To install:
ADJUSTMENT
C6 Transmission
4R70W Transmission
Adjusting the MLP sensor
Park is the last detent when the manual control lever is full forward. Return 2 detents toward the output shaft for Neutral.
I hope help you. Good luck (rated this help).
