This might cover it.
http://www.4shared.com/office/L6S9BH...ction_4G.html?
SOURCE: neutral safety switch
It is located on the side of the transmission, follow the shift cable down to it you will recognize it because it has a electrical wire comming off it and either a shift lever or shift cable going to it.
SOURCE: Where is Neutral safty sensor switch located on Grand Cherokee
OK then the switch is part of the gear selector switch on the side of the trans where the shift linkage hooks up. here is a picture and part number.
ACDELCO Part # C2241 $233.89
SOURCE: need to locate the neutral safety switch on a 2005 chevy equinox
The park / neutral switch is on top of the transmission. It has a 2 wire connector. the wire colors are pink and orange/black. Tech jk
most gm nuet safety is yellow and purple .....out of ignition switch is a big yellow wire that is crank out and input to nuet saf switch......out of nuet switch is color purple that goes strieght to start selenoid.....purple wire also goes to the crank fuse 5amp.. in the fuse box under dash... this fuse goes to the pcm main computer.. same for auto and clutch
