SOURCE: using dnr garmin or map source how do I transfer from excel
I've just had to do this. Somewhat annoying and I'm sure there must be a quicker way. Let me know if you find one. <br /><br />Firstly you need ArcGIS or something that can create .shp files. Load the Excel file into this. In Arc you need to right click the table and display the x y data (just to make sure it's all okay). Then save as a layer. Then export as an .shp file. <br /><br />You can the open the.shp in DNRGarmin and upload to your GPS..,<br /> <!-- from fixya rte -->
SOURCE: my garmin GPSmap 78s is
The sd card must have corrupted.Or the socket in which sd card is got installed is dusty or moisture collected there.Also try checking with another spare sd car and see if that is getting detected and reading.If its getting detected,then your sd card is corrupted.But if other sd card is also not getting detected.Then its gps module problem,where sd card is fitted.Try the reset and see if helps.Turn off the gps for few minutes then remove the battery then insert battery and on it . ---------- also you can try restore factory defaults.Click menu in that select default and after then press enter.Then see.----------- --------------- this should help.Thanks.Helpmech.
SOURCE: Database Error show on screen Navigation database
Contact me directly, my e-mail: [email protected]
