Hi Anonymous, search Google, LCD Panel for Philips TV 55PUT6233 / 56
Keep in mind that replacing the panel has its risks
Good luck in the search
Regards Franco Dosil
Hola Anonymous, busca en Google, Panel LCD para TV Philips 55PUT6233/56
Ten en cuenta que reemplazar el panel tiene sus riesgos
Suerte en la busqueda
Saludos Franco Dosil
SOURCE: tv screen is cracked
try www.tvscreenprotectors.com
they help with finding discontinued tv screens
SOURCE: 55 inch Philips
I have 50" philips magnavox big screen. I recently started to have a problem with the edges of my tv. They became blurry. the center of the tv is clear and the edges are blurry. what should I do to fix this problem.
SOURCE: I have a Philips 55pw936317f 55 inch tv that has pic problems.
Same problem here, wish I knew how to fix it... I noticed it can be helped a little if you adjust the convergence from the menu using the remote though.
No--this is called a PDP or plasma display panel and no two (even same brand) can be interchanged.
The cost of a Panel exceeds the cost of a new set--broken screen=fatal issue.
