SOURCE: starts bleeping 10mins into cycle
http://www.manualnguide.com/dl/12334/ Check on the troubleshooting page as to what certain flashing sequences mean and that may help
SOURCE: err 2 keeps bleeping
adjust the speed sensor, see the diagram attached , clean, and tight the connector very well.
2)Test the input voltage motor, if there are the motor need repair.
3) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
4) Run the software calibration for diagnose, troubleshooting.
sincerely. God bless you
Hey Beverley, thanks for your post!
I see that your Electrolux washer is displaying the error code "ERR". Typically a number follows the "ERR" but if no number followed the "ERR" error code then your washer has detected an error. I would perform a reset on your washer which can be done by unplugging the power cord or flipping the household circuit breaker for roughly ten minutes.
If that does not help correct the issue it could be a problem with your control panel or wiring harness. I would recommend seeking out assistance from a professional in order to properly diagnosis and repair your washer. I hope this is helpful to some degree. -Matt
