Garden Logo
Anthony Bowenford Posted on Aug 23, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you adjust the deck belt on a Toro LX 420 riding mower?
Thomas Perkins
Level 3:
  • Toro Master 15,088 Answers
  • Posted on Aug 23, 2019
Thomas Perkins
Toro Master
Level 3:
Answers
15088
Questions
0
Helped
3385470
Points
54869
The deck belt is not adjustable, it is tightened by the number 26 spring. Spring can loose tension or the belt could be stretched.
5 Related Answers
Anonymous
  • 6 Answers
  • Posted on Apr 06, 2009
SOURCE: how to install mower deck belt on a lt1000 craftsman riding mower
The manual will cover it.
http://www.disruptit.com/manuals/L0104168.pdf
Anonymous
  • 6 Answers
SOURCE: Craftsman riding mower loose belts need tighting
http://www.disruptit.com/manuals/L0403195.pdf
Here ya go.
Anonymous
  • 6 Answers
  • Posted on Apr 22, 2009
SOURCE: need diagram for deck belt
Try http://www.rcpwparts.com/parts.asp
Anonymous
  • 2559 Answers
  • Posted on May 15, 2009
SOURCE: i need a manual to show me how to adjust the belt
Here is a link to the manual
Please rate this a fixya.
mickey813
mickey813
  • 472 Answers
  • Posted on Nov 19, 2009
SOURCE: We have a Weatern Auto Wizard Riding Lawnmower.
19c5756.gifHOPE THIS HELPS LET ME KNOW
My toro lx 420 wants to stall when engaging the blade sometimes..also when I push on the reverse, it acts like to wants to stall as well...any easy troubleshooting ideas? runs fine when not engaged
Try rolling when you engage instead of in the still position may be too much on the motor, either that the belt is loose or needs to be replace. Or u need a carb adjustment at the idle.
How do I remove mower deck on Toro riding mower 1986
First put the front on a jack stand on high. then lower the deck all the way down. Look at the three places on each side to remove the pins that hold the deck on Then there should be two in the front of the deck, remove them. Remove the belt from the motor pully. Lower the mower to the ground and release the peices the pins were in. Remove the clip from the tension cable and remove the cable from the deck. Raise the mover to pull out the deck. Reverse to instal
I hope I helped you
Oct 04, 2014 • Toro Garden
Does the hour meter in a toro tractor lx 420 show Tenths?
Best way to check that out is to run it for six or seven minutes and see it the number changes by .1 and if it takes an hour of running to move the nkmber you will know that it reads hours nit tenths.
Sep 21, 2014 • Garden
1helpful
I need a diagram to replace belt on a 60 in deck on a John Deere 420
Make a loop with the three drive blade pulleys, the other two are tensioner pulleys, if they are flat pulleys as they should be the back side of the belt rides on these , if they have been changed then use them as tension pulleys anyway you can, hope this helps.
1helpful
Blades keep running in all gears on my mtd 420/38
Assuming you have put the blade drive lever into 'disengage' check the blade drive belt tension. With blade disengaged, belt should have significant slack. You may need to adjust the control cable, adjustment is usually on the mower deck; or you may have some debris on the deck preventing the pully to release belt tension
Jun 26, 2014 • Garden
1helpful
Toro lx 500 riding lawn mower
check the connections from the battery to starter-check the fuses -and relays than start with the safety switches --seat-clutch-and cutter deck the safety switches are a kill switch
May 24, 2013 • Garden
My deck belt keep falling off my Toro riding lawn mower
look at the pulleys for play also how is the spring tension ?
Jul 08, 2012 • Toro Garden
Toro lx 500 deck belt pops off
check for play in the bearings blade bearings and the idler pulleys
Apr 14, 2012 • Toro Garden
1helpful
I have a toro lx500 riding mower. the blades won't engage.
Check the belt on top of the mower deck. Make sure the belt didn't slip off or break.
Top Toro Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a Toro Garden Expert? Answer questions, earn points and help others
