Could also be the governor spring which automatically controls engine rpm. Under load, the governor would rev up engine to keep at optimum cutting rpm. If spring is weak, bent, or mis-adjusted, surging can happen. It is possible to adjust spring, but to do correctly, will need some way to measure rpm, and not to meby, the recommended operating rpm. Might have to replace spring if it is damaged, that is saying it is the spring. I agree with a tune up first. Plug, air filter, and fresh fuel.
SOURCE: 2 1/2 Briggs......doesn't run smoothly....surges at all speeds.
Hi, Check that you have the correct spark plug fitted or fit a new one as it sounds like your plug is getting hot then shorting out.
Sometimes the magnito can do this as well. but I would start with the plug.
Sorry, this section is for Measurement Tool Questions only.
