Garden Logo
Chris Taflinger Posted on Aug 23, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Changed belt on Toro lawn mower and now won't move blades pto works but won't move
Jim flowers
Level 3:
  • Toro Master 1,098 Answers
  • Posted on Aug 25, 2019
Jim flowers
Toro Master
Level 3:
Answers
1098
Questions
Helped
359407
Points
2966
What belt did you change? i assume the drive belt. if it is not exactly the right size it wont work. if it is not routed correctly it wont work. it may have slipped off of a pulley.
5 Related Answers
Mike McDowell
  • 148 Answers
  • Posted on May 19, 2009
SOURCE: Need Parts/Service Manual for Toro HMR1600 mower.
Go to www.managemyhome.com and put in your model # for the manual (You can download to your computer). Also try www.searspartsdirect.com and put in you model # and you should be able to see all the parts for your mower.
Anonymous
  • Posted on Jun 29, 2009
SOURCE: Sovereign SLM 1500 lawn mower blades have stopped turning
The belts are available part number is SV150. Call ALM Manufacturing 01423 797208 for advice/stockists.
Anonymous
  • 1627 Answers
  • Posted on Jul 29, 2010
SOURCE: problem with John Deere L120 tractor
Park brake switch is the most likely culprit,any other would cause the tractor to not turn over in the crank position.
Anonymous
  • 6468 Answers
  • Posted on Mar 25, 2012
SOURCE: front wheels do not move on self propelled lawn mower
check the cable at the front gear box
Anonymous
  • 6468 Answers
  • Posted on Mar 30, 2012
SOURCE: lawn mower belt is rubbing on something. its a craftsman 42
check the idler pulley
Troy Bilt 33" walk behind mower blades won't turn on.
Troy-Bilt Lawn Mower Blades Won't Engage - Model ...
www.repairclinic.com/...Mower/...-/Troy-Bilt-Lawn-mower-blades-won-t...
Most Frequent Causes for Lawn mower blades won't engage. See All Lawn Mower Parts for model 13AP60TP766. Cause 1 PTO Clutch. If the blades don't rotate the electric PTO clutch might not be engaging. ... Lawn mower wheels don't turn ...
Nov 08, 2015 • Troy Garden
2answers
My pto is on all the time on my Toro zero turn. Blades are engaged when I start the engine even though the switch is in the off position? What would cause this?
Haven't had your particular problem, but my my blades would not turn when I pulled the PTO control knob. Turned out to be a bad PTO switch. Mechanic replaced the switch and it worked fine thereafter.
Why doesn't my Toro z master PTO not engage
check to see if pto will engage if not check voltage at pto if non blown fuse if fuse not blown and power to pto bad pto jump the pto at pto with battery in mower does it start pto if does good pto have to check volts at switch check there start with that let me no what happened
Time cutter PTO clutch switch clicks when I engage the switch but will not engage the belts
Check under the deck and make sure the blades can spin freely, there will be resistance but mostly check to see if they are stuck. If they are not and can move, you can try to remove the belt from the pto, engage and see if it spins then. If it does not than there is probably an issue with pto clutch
Cub cadet 1040 blades spinning when pto isnt engaged
Sounds like you forget a spring or the routing belts are
wrong.
1helpful
2helpful
2answers
Cub Cadet LT1042 PTO won't disengage
If its an electric PTO then the switch on the dash is bad, Its a lever type ungagement then the little break shoes that rub on the blade spindles are either worn out or mis adjusted.If it started when you changed the blade drive belt its possibly the wrong belt??
Top Toro Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a Toro Garden Expert? Answer questions, earn points and help others
