Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
Posted on Sep 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Starts and runs until it gets hot.
Will run like normal until the engine gets hot (approx. 20 min.) then sputter and die. Let cool for about 30 min. and the cycle repeats itself.
_good spark from magneto
_clean air filter
_new spark plug
_correct amount of oil
_deadman switch in working order
I'm starting to suspect either the carb or valves. Any ideas?
Anonymous
Level 2:
  • Expert 246 Answers
  • Posted on Sep 13, 2009
Anonymous
Expert
Level 2:
Answers
246
Questions
0
Helped
260616
Points
748
Hello:
Your Problem can be Caused by Several Possible Items.
>>The Following is a Basic Instruction File I made for this. Any Input is Appreciated. I Usually Suggest you Check the Following in this Order for a Problem like yours. 1- Check the Gas Tank Cap and Ensure it is Venting the Tank. A Vacuum Builds in the Tank and the Gas Flow Stops or Slows (15 to 45 Minutes and if the Small Grainular Sand is in the Tank it can Take Several Days of Constant Running to Bring All the Sand Particales to the Tank Outlet Port) to a Point it Shuts Off the Engine. 2- Operate the Equipment Until it Quits (15min to 1hr). Then Immediately Check for Fire from the Plug. If the Plug is Firing, then 3- Check the Carburetor Solenoid. If the Carburetor Shut Off Solenoid has Current, then Remove the Carburetor Solenoid and Go to the Hardware Store. Purchase a Bolt of the Same Diameter and Threads. It Needs to be 3/4" Long. Put this Bolt in Place of the Solenoid. If this Corrects the Engine Problem, then Replace the Solenoid. ***NOTE: THIS IS FOR CHECKING THE SOLENOID ONLY I NEVER SUGGEST YOU OPERATE THE ENGINE WITH THE SOLENOID OUT OF THE CARBURETOR EXCEPT FOR TESTING PURPOSES*** Sometimes the Plunger is Moving, Just Not Far Enough to Allow the Gas to Enter the Jets. 4- Depending on the Model Mower, it can Also be the Pickup Tube in the Gas Tank. If No Fire, then Remove the Shut Off Wire from the Coil and Check for Fire. If Still No Fire, then the Ign Module or Coil is Bad. **Even if the Coil is New of Fairly New, it can Still be Bad.** On JD Mowers; Remove the Igniter/Module and the Coil and have the Local JD Dealer Test them.
>>Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Kawasaki lakota 300 starts and runs great for about 10 to 20 mins then starts sputtering and dies after it sits for about 30 or more mins it starts again. pulled plug no spark after it dies.
problem ignition control module or coil/s
electronic component failing when getting hot
replace coil /s and or ignition control module
How do I adjust my Holley 4 barrel on a 4.3 liter chevy engine. Starts and runs fine till it warms up then dies and won't start for 30 min.
sounds like your coil is getting hot then when it cools down the engine re starts check coil look for hot spot or touch it see if it is hot it should be cold.
Starts up and runs ok. 30 min. dies and won't start for 20 min. then won't run. Have to wail untilsomething cools down???
A simple solution is to check your air filter. Is your engine temp high? It could be a sensor too.
1helpful
Fuel pressure intermittently drops causing sputter and die.
check for 12v constant at your fuel pump if you are not getting that replace your relay.
if you are getting 12 volts at your fuel pump the fuel pump is possible to run tuel it gets warm then shut down to a lower rpm I would then replace the fuel pump
Stalls when hot
it is overheating. first thing to try is ****** the timing, to run cooler, as you have just replaced the points.-plz rate -bozcro
1helpful
2005 Poulan PD17542LT Lawn tractor, It starts fine but after cutting my front yard (20-30min) it dies, it will start up but dies in a few sec. If I let it set and cool off I can get 20=30 min till it gose...
Normal maintenance been applied to this rider ? Filters, lube, cleanings ? This sounds like an electrical issue (component hot), or a vacuum in the fuel tank. Next time it 'stops' open the fuel tank up and listen to any air 'whooshing' in.
2answers
Runs for 20 seconds then dies
Check the fuel pump, make sure it is putting out proper pressure if not then change the fuel pump
Top Craftsman Garden Experts
john h
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
