SOURCE: Trouble with my canon copier ir 2870
E000602-0113 means that the hard drive is having problems booting up. You may try to remove the boot chip and clean the contacts with rubbing alcahol and reinstall it and turn the copier back on. Most likely you will need to replace the hard drive or try to re-flash the hard drive.
SOURCE: we have canon copier ir 2016j, it started giving
Error code E007 on an ir2016 means that the fuser film has a fault. The fuser film is the black sheet that melts the ink into the paper on the final stage of the copy process. It more than likely has ripped apart. You will need to call a service tech for this one.
SOURCE: canon copier ir 2016 giving error msg E 246
Hi, these error code isnt in service manual.The Canon says that you need to report these problem to your authorized dealer.
SOURCE: Canon IR 2270 The copier print
these means that copier cant detect the toner in developing/toner assy.
You should try to reconnect the toner developing assy and try to vacume it.
Also check if the toner bottle is rotating, if yes that means that toner is being dosed and problem is developing assy.
If you do not want to call service write me on [email protected] for service manual.
hope that helps!
Testimonial: "very helpful i just remove check and reconnect the toner cartrige and the issue is solve "
