What i have found is there is No Noise, No motor spin and the buttons dont work most likely because there is no DVD to control if anyone has info on how i could fix this please let me know thanks :)
SOURCE: EMERSON DVD PLAYER CLICKING NOISE..DISC ERROR MESSAGE..HELP!!!
Had a similar problem. Called for support, but was told needed new reader. I took off the cover and manually slid the reader mechanism back and forth a few times. After doing this, tried another dvd and it worked. Apparently it was stuck and not able to move to read the dvd. Give this a try.
SOURCE: AWA DVD Player DP208
Press "V-Mode" on remote control. Answer courtesy of AWA Warranty Support.
My thanks to FixYa and hopefully of benefit to other readers.
SOURCE: ilo dvd player/recorder
OK I called the Philips and since mine is already programmed he walked me thru how to retreive code. He said 1906 on the VCR button. Hope it works for you KCGIRL.
SOURCE: Error Code:DVD HO2
try to clean it first bring cleaner cd from radio shack. put your cleaning disk in and let it run-remove cleaning disk and put your disk and try,
SOURCE: AWA DS-A331 DVD PLAYER REGION CODE
(1) Open tray with remote
(2) Enter 0,5,2,0 on the remote
(3) Press up, down, left then right
(4) Press 0
(5) Close tray
