If you need to have a new diesel generator set, please contact us by this email address [email protected]
SOURCE: No voltage output
It is possible that your voltage regulator is shot but before purchasing the volt regulator try flashing the fields first and make sure the brushes and rings are clean.
SOURCE: I have a honda generator em2500x voltage problem
Cummins P2200, 2KWatt, it starts fine, but after a couple of minutes, it gives quite high voltage output, meter needle goes beyond 300v, engine speed seems high since throttle is increased, indicator light on generator also becomes bright, after a minute or so, things come to normal, sometimes takes few minutes to come to normal, situation is same, with/without output load. this happens within initial 15 minutes after startup, afterward everything is normal.
SOURCE: HOME DEPOT GENERATOR HUSKY 5000 NEED PARTS LOCATED FOR GENERATO
bring the entire thing back... ask to speak with the manager and demand a brand new unit... (husky is exclusive to home depot..fyi)
if they give you push back ask for the district managers phone number (they have to provide or they can be fired) but they will replace it before he gets envolved..
if that fails try posting this in the correct category (this is motorcycles)
SOURCE: ust 3000 generator-only idles-no voltage output
chek brushes...if they seemed ok then replace AVR card
SOURCE: I need the fuel line routing or diagram for a
Jimmy there are no Poulan drawings with fuel system detail worth the ink it takes to print them, but that is all there is.
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
Routing runs from fuel tank to carburetor, (if equipped) through carburetor to primer bulb (once compressed bulb draws fuel as it returns to normal) , bulb (as it is compressed) returns displaced to fuel tank. HTH
Lou
