Hi Sonya, ask, is your CD player Teac or Yamaha?
From what you say, your Compactera is in repeat 1 mode, which tells you that it will repeat the same disc or song
look for the REPEAT button on the front of your CD player and press it until the REP indication on the display disappears
If it is a Yamaha CDC635, I send you the link of the user manual
I hope you can hear all the songs
Regards Franco Dosil
Hola Sonya, pregunta, tu reproductor de CD es Teac o Yamaha?
Por lo que comentas, tu Compactera esta en modo repeat 1, lo que te indica que va a repetir el mismo disco o cancion
busca en el frente de tu reproductor de CD el boton REPEAT y presionalo hasta que desaparezca la indicacion REP del display
Si es una Yamaha CDC635, te envio el link del manual de usuario
Espero que puedas escuchar todos los temas
Saludos Franco Dosil
https://es.yamaha.com/files/download/other_assets/2/313792/CDC-635.pdf
SOURCE: Teac GF-350 CD Shelf System
Firstly double check that the recordable discs you have bear the label "Digital Audio" on them as per the attached picture. Secondly what happens when you go through the finialise procedure in the manual? Do you see the ?FIn--d? display when you select the finialise button? Do you see ?NO TOC? and ?REC? indicators blinking at the next step? Please update the question & let us know if the information given was useful to you - Good Luck!
SOURCE: CD player won't play disk and says "no disk"
The problem of "'no discs'"displayed is in the mechanism in the roller thats moving back and port bringing the lense set .The old grease thier is already hardened that cause the problem.Clean that by using a lighter fluid or like that fluid to take the old grease,and put it with a new one first class grease type-A grease put only a little grease and wipe the lense with a cotton buds without any chemicals on it .Try this solution so performance will be better.
SOURCE: yamaha cdc 555 5 disc cd player
If you trust yourself enough to open the case w/o breaking stuff, then open it up UNPLUGGED, locate the laser lens (small,clear,plastic) gently clean the lens with a swab of lens cleaner for glasses.
Also clean the chrome runners that the laser assembly tracks on.
SOURCE: teac lp- u200 cd player doesn't work
Sicne this is a new system, don't waste time on it. Return it for an exchange. The CD portion is not working. The reading message indicates that the unit detects a disc, but can not read it. This is usually a problem with the optical assembly or the processing board. Neither should be a problem at this time. Replace it under warranty.
Dan
SOURCE: ford 6006 cdc cd player wont accept correct code
Either the code is incorrect or you are using the wrong Code Entry Instructions.
To check your code POST ANOTHER QUESTION quoting the radio`s SERIAL NUMBER ( can be found on the radio casing or by pressing either buttons 1&6 or 2 & 6 )
It normally begins with M + + + + + + (or V or L or C )
