Question edited for clarity 'Olivia' to 'Olevia'.
Sounds like a faulty relay, or a faulty Triac which is an electronic switch. Eventually it will stop responding to the double switch on.
It is not a well known brand
https://www.google.com/search?q=Olevia+Television
SOURCE: I have a Olivia television flat screen. after a
If u have no power lites lit up on the tv, then it may just be a blown fuse. if not then the power supply board would need repairs. should be taken to a shop
SOURCE: television that is about 4 years old. we were
is your power suply occileting all th time or are lusing the on signal from the main board.
SOURCE: I have an older 12 year old 37" Toshiba tv. When I
A capacitor in the vertical circuit is taking time to build up a charge, and allow the vertical circuit to function properly. If you can get a schematic, you might be able to find it and change it out. It will be an electrolytic capacitor, shaped like a round barrel, and they are inexpensive, but you have to disassemble the whole unit to get them changed out.
I would live with it, unless you're very adept at electronics.
I could work for years like this, until it finally gives out.
Good luck, and hope this helps.
Testimonial: "Thanks for the information. My plan was to just let it run until it goes and then replace it. So this is very helpful and supports my thinking. "
SOURCE: I have an Olivia LCD LT23HVX TV., it will not turn on at all. no sound or picture. Can you help?
In other words, your TV is in dead condition now. Check for any blown up fuse on its main power regulator board. You must have to open the TV to access it.
