SOURCE: 8360 new holland tractor tansmission oil pressure
havent worked on one but if oil pressure light is showing on the gearbox then something is wrong ,either oil is low or the pump has packed up or the pick up pipe filter is blocked .either way what i do know is that seperating the units is a big job requiring specialist equipment which no doubt you know already,
SOURCE: Tractor Front end loader will not dump
Could be a lot of things. Quoick coupling loose? Does the lever work from left to right? Is it stuck now and only work from front to back? There is a small lockout feature on it that keeps from it moving when you hit it with your legs. It is down at the base of the lever. Other than that has to be connections. Try swithching the hoses around where up and down is dump.
See if its that
SOURCE: new holland tractor won't start just clicks
check both batt. termial ends,also check cenections at the starter and the ground wire,if that wont fix it next maybe charge batt .
