Hi Anonymous, for what you say you may have a problem with the remote control, that the Speakers A and B keys are emitting and generating the fault, remove the remote control and check if the fault continues, if so, try resetting the team
I pass you the link to download the user manual, look at page 65, the procedure for the reset
I hope you can solve it
Greetings Franco Dosil
Hola Anonymous, por lo que comentas puedes tener un problema en el control remoto, que las teclas de Speakers A y B, est?n emitiendo y generando la falla, retira el control remoto y verifica si continua la falla, si es asi, prueba resetear el equipo
Te paso el link para que descargues el manual de usuario, fijate en la pagina 65, el procedimiento para el reseteado
Espero lo puedas solucionar
Saludos Franco Dosil
https://www.vintageshifi.com/repertoire-pdf/pdf/telecharge.php?pdf=Yamaha-HTR-5930-Owners-Manual.pdf https://www.manualslib.com/manual/197345/Yamaha-Htr-5930.html
Testimonial: "Franco, I removed the remote and it seems to have worked!!! Thanks a ton!!! Excellent diagnosis."
Well, I'm glad you could solve it
try to carefully disassemble the remote control, clean the template of the rubber contacts with warm water and a neutral detergent, the plate with some type of glass cleaner, remove the residual rubber and silicone that remain in the contacts, do not use alcohol
Let everything dry and test if the problem was corrected
Thanks for your comment
Regards Franco Dosil
Bien, me alegro que pudieras resolverlo
prueba desarmar con cuidado el control remoto, limpia la plantilla de los contactos de goma con agua tibia y un detergente neutro, la plaqueta con alg?n tipo de limpiador para vidrios, s?cale el residual de goma y silicona que quedan en los contactos, no uses alcohol
Deja secar bien todo y prueba si se corrigi? el problema
Gracias por tu comentario
Thanks Franco,I could manage a replacement for remote
SOURCE: Yamaha HTR-5990 Receiver
I JUST EXPERIENCED THE SAME SITUATION HERE IS THE SOULTION YAMAHA SENT ME TO RESET THE SYSTEM HTR-5990 YAMAHA HTR-5990 FACTORY PRESET PROCEDURES All models require the STANDBY/ON button to be turned OFF to start the reset process. NOTE: The remote control cannot be used during the reset procedure. All necessary buttons to complete the reset process are located on the front panel of the receiver. This procedure is not intended to correct intermittent shut-off symptoms or problems MODEL: HTR-5990 (U.S.A. model/s) (BEFORE YOU CONTINUE, PLEASE READ THE ABOVE NOTES!) 1. Before you start this procedure, locate the MASTER ON/OFF button and the STRAIGHT/EFFECT button on the Front Panel of the unit. 2. MAKE SURE THAT YOUR RECEIVERS MASTER ON/OFF HAS BEEN TURNED OFF. 3. With the Right Hand, press and hold the STRAIGHT/EFFECT button. With the Left Hand, press the MASTER ON/OFF button and HOLD both buttons for no more than 3 SECONDS, AT THE SAME TIME. SP IMP. * 8 MIN. will appear on the display, which indicates you are in the Diagnostics Mode. 4. Rotate the PROGRAM KNOB to the right (ONCE) until the display reads PRESET *CANCEL. 5. Press the STRAIGHT/EFFECT button (ONCE) and the display will change to PRESET RESET. 6. Turn the unit off by pressing the MASTER ON/OFF button. 7. Wait 5 seconds, then turn the unit on by pressing the MASTER ON/OFF button. You have now reset your component to the factory settings. NOTE: Yamaha receivers dont have to be reset during normal operation. It is not recommended that you reset the receiver unless a setting has been changed that you are not aware of, or the receiver is not operating properly. The reset procedure will clear an incorrect setting that might be causing abnormal operation. GOOD LUCK
SOURCE: No video signal on Yamaha HTR 5930
On , HTR-5930, composite inputs are routed only to composite outputs. The same happens to component input. You can't see video from V AUX if your TV is hooked-up on component output. Also, check if you connected correctly GREEN, BLUE AND RED on both receiver and TV SET.
SOURCE: Yamaha HTR-6130 Front right and left speakers with no sound
As simple as this sounds, try hitting the speaker a/b button on the front of the unit, next to the headphone jack. I had the same problem, and was about to package the whole thing back up and go back to Best Buy when I hit this button and then the audio test worked.
SOURCE: Yamaha HTR-6130 sound only from centre, rear or front speakers
its not how there connected its in your settings. rehook up all your speaker connections properly,then make sure you proram the reciever to recieve fiber optic,hdmi,digital coax etc in the reciver.
SOURCE: Yamaha HTR-5660 receiver but no surround sound
have you tried putting it in a different program mode?
