SOURCE: beater brushes wont work
Sounds like you really need a new belt. Don't know why it is taking so long for you to get one. But belts stretch and then won't turn the brush roll under load. Call around to your local repair shops, must will a good selection of belts on hand.
SOURCE: Beaters stop when vaccuming rug...didn't when new
I believe you need to change the belt that drives the brushes. When it gets stretched out, it will just spin on the axle of the motor or spin on the brush and smoke.
Jim
SOURCE: motorized brush bar not turning on Dyson Vacuum
Apparent common failure is that either the thin yellow and or blue motor drive wires that run from the LH side of the vacuum where the "control board" is located down into the hinge / ball area become stretched and then fray and eventually break. Happened to my Dyson twice. First repaired under warranty, second took about 20 minutes. You need a Torx screwdriver to remove the LH panel ( 4 screws) and also an access panel (2 screws) at the side of the ball which permits access to the blue / yellow wire connectors. I replaced with a new wire and connectors having fed the wires through the access hole making sure sure enough wire was available for the movement of the handle. Also ensure that when the covers are replaced they do not trap any wires underneath.
SOURCE: carpet cleaning brush noise
It's likely that one of the brush roll bearings has worn out. This is not uncommon. I think you'll find that you have to replace both the brush roll and the sole plate at the same time. Dyson sell them together as a kit.
CARPETS OR HARD FLOORS
ā¢ The brush bar will always default to 'ON' (spinning) each time you switch the
appliance 'ON' and recline it for cleaning.
ā¢ The brush bar will not rotate when the appliance is upright.
ā¢ To switch the brush bar 'OFF' (e.g. for delicate rugs and hard floors):
- switch the appliance 'ON'
- recline the appliance
- press the brush bar 'ON/OFF' button - the brush bar will stop spinning.
ā¢ The brush bar will automatically stop if it becomes obstructed. See 'Brush bar -
clearing obstructions'.
ā¢ Before vacuuming your flooring, rugs and carpets, check the manufacturer's
recommended cleaning instructions.
ā¢ Some carpets may fuzz if a rotating brush bar is used when vacuuming. If this
happens, we recommend vacuuming in 'hard floor' mode and consulting with
the flooring manufacturer.
ā¢ The brush bar on the appliance may damage some carpet types. If you are
unsure, turn 'OFF' the brush bar.
