You can change the settings of your mouse in the control panel even with windows 10. Click the start menu button from the home page. Windows 10 search for the control panel. Windows 7 users click control panel. Go into mouse settings. From there you can edit the click speed, mouse speed, etc.
In Mouse Properties you can select single or double-click for opening files. This may resolve the issue. If your touchpad has a separate properties/adjustment window you will see the same options there. Select double-click.
SOURCE: PC MOUSE
Plase try to lower the double click speed which is found in control panel-mouse-pointer options Hope this will slove your problem
SOURCE: touchpad stopped working arrow still works
sounds like you need to adjust the sensitivity, as you can customize this to prevent accidental double taps.
you should have some software to configure your touchpad, this will either be from the manufacturer or you can use the "mouse settings" in control panel.
SOURCE: problem related to touchpad not working properly
for you have used the machine for more than 1 year then your touch pad need to be replaced however if it has happened abruptly then reinstall the touch pad drivers
SOURCE: How do I disable double-click on an HP Pavilion dv4 touchpad?
Hi there Dublin. I recently bought a HP laptop myself, and I believe I can help your situation, or at least I hope I can. Here's what you do: Access your Control Panel>Click Mouse>Click Device Settings>Click Settings> Click Tapping> Click Disable Tapping. That should do the trick. You are not disabling your touch-pad, just the double-clicking that is associated with it. Drove me nuts for about a day, 'til I figured it out..Hope it worked for your notebook.
SOURCE: Can't open shortcuts with double click but can
Scan your system with malware bytes and trojan remover
http://www.simplysup.com/tremover/download.html
and
http://download.cnet.com/3001-8022_4-10804572.html?spi=1b215ac91f2f852150b6cd171d8748fd
Else create new user
3. Click the Touchpad tab. This tab can have one of several names, depending on your computer manufacturer, your operating system version and your device drivers. However, the most common labels include "Touch Pad," "Device Settings" and "Dell Touchpad." If you do not see any option resembling these, you may not be able adjust your laptop's touchpad settings. Refer to the "Warnings" section if this applies to your computer.
4. Locate the "Scrolling Settings" area within the touchpad properties tab. Adjust the settings to meet your needs and then click "OK" to close the dialog boxes and confirm your changes.
Click the Apple menu and then select "Preferences."
Click the "Keyboard & Mouse" icon.
Select the "Trackpad" option from the top of the Keyboard & Mouse dialog box.
Adjust the trackpad settings to meet your needs, and then close the dialog box to confirm your changes.
