SOURCE: Toshiba CZ32V51
two things can be affected, a tuner if you were using out door
the other one is the power supply. the tv sensed a high voltage (surge)
firstly you need to repair a supply, check the following.
i rectifier diodes at the power supply
ii power trasistor, driver trasistors diodes, zener diodes
ii fusable resistor near a power transistor
after the tv will come on ----if they will be light on the tube then test a tuner, by putting in signal.
SOURCE: Toshiba 32A60 wont click on, like it is stuck.
T.v.s are dangerous but if you are carful you could try changing the fuse.
SOURCE: power went out during electrical storm. tv never
it is problem power supply some of components are demage such as capacitor or diod is bad. You go to a service centre and repear it by a good technician
SOURCE: Bad storm, lightening strike outside
I would start with your power supply. If you took a surge it is possible that you only blew a fuse. If it is a blown fuse, make sure you only use the same type fuse.
SOURCE: power went off during rain storm unit would not come back on MSZ12UN
May be short circuit. Call electrician to check and replace the fuse or reset the circuit breaker.
