Hi Vernon, indicate brand, model and type of equipment you are commenting on, in order to find the best possible solution
I wait your answer
Regards Franco Dosil
Hola Vernon, indica marca, modelo y tipo de equipo del que estas comentando, para poder encontrar la mejor soluci?n posible
Espero tu respuesta
Saludos Franco Dosil
SOURCE: kenwood KRF-V6070D no audio
• If you have a multimeter, check for DC outputs on the amps,
coming from IC301/401 (hybrid IC)
• Or use a headphones .It could just be some cold solder joints
( if there is no humming in headphones) or regulators
on the power supply.
• Check other inputs, you might find one working.
Let me know if you need further assistance!
SOURCE: is audio output from main ic input to utc2003 audio amplifier ic?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Was it working before? Are you using it as aTV or Video (Video = when a decoder or DVD player is connected)
