Televison & Video Logo
A
Annie Posted on Aug 20, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I want to reset my channels on my LG tv I have been through menu, settings then auto tuning and all I get is about 18 programmes the only info I can give you is the remote number akb69680403. Annie
mikemail1
Level 2:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Expert 95 Answers
  • Posted on Aug 21, 2019
mikemail1
Expert
Level 2:
New Friend:
Night Owl:
Answers
95
Questions
0
Helped
30548
Points
286
If all you got when you did the auto setup was 18 channels, that is because that's all the channels that your tuner could pick up in your area. There is no additional settings you can make or changes that will give you additional programs without an improved antenna system. Without knowing what kind of antenna you have there's no way to suggest an improvement.
5 Related Answers
Anonymous
  • 3130 Answers
  • Posted on Feb 03, 2008
SOURCE: Lost the Manual & can't tune digital channels, option not available on menu ?
Here is a link where you can down load a free copy of your customer user manual. Good Luck
http://esupport.sony.com/US/perl/model-documents.pl?mdl=KV32FS120&LOC=3
Anonymous
  • 859 Answers
  • Posted on Oct 23, 2008
SOURCE: When auto tuning my LG
The ABC channels arrive on a different Harmonic than Analog signals; specifically the third Harmonic. When you auto tuned, the auto tune chip looks for stron analog channels on the first harmonic and any other strong signals. However the LG model is notably poor at capturing 3rd Harmonic signals.
Harmonics are different frequencies where the same signal can be captured. Making this overly simplified: a frequency multiplied by 2 is a harmonic and that multiplied by 2 is also of the same harmonic; inversely dividing by 2 and 2 gain and so on finds harmonics down in light wave frequencies.
You may be able to manually tune these ABC frequency channels manually (I do not know, as I live in the US and have no direct experience with this) and then add them in one by one. But, using the Auto Tune feature again will wipe those out. The same thing happens to other weak signals, which harmonic is actually (its on an offset carrier wave).
I just read of a man who built an improved antenna and put this in his attic and received ABC channels quit well. A decent understanding of Antenna physics is required, but it only took up 1.5m wide by .8m (sic) long. In a nutshell he improved his basic antenna by building his own more sophisticated antenna.
Shopping around and asking in the shops should get you an antenna add on that will work for you.
As I stated before I live in the US, and we don't have this, but I and others here at fixya have various experience in amateur radio.
I will ask a friend of mine who lives in Australia to confer with me on this problem of yours so he can add some value to our response to you.
Regards,
Worldvet
Anonymous
  • 273 Answers
  • Posted on Jun 03, 2009
SOURCE: unable to tune in my LG Electronics TV (model 37LC2d-ec) to receive digital channels. Bought in UK, now living in Australia.
use a scart lead connected between your digital receiver to your tv
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Jul 28, 2009
SOURCE: How do i manually add a digital channel to my tv? model: ILO-26HD
do u have the user manual for the TV? if you do the solution will be in there, if not (I suspect you don't) please give the make an model so I can try to look this up, but off the top of head there is no way to "assign channels" to a paticular remote setting.
Anonymous
  • 5 Answers
  • Posted on Sep 16, 2009
SOURCE: How do I tune TV channels on my Sharp CX48G4 TV without a remote control? There is no tuning / settings panel on the TV itself which is very strange.
press the preset button on the front panel once then (TV should be on) the on the screen there should be words the likes of (Auto VHF 1 60.00mhz) now the Auto stands for auto tuning VHF stands for its frequency where its going to search the 1 stands for the channel where its going to start with 60.00mghz stands for the lowest signal to which its going to start now that you have understood all that just press the volume up button then it will automaticly locate all your working channels leave till it stops for when does it will start from channel 1 to which I believe that you be able to see the channel working so press the up button on the channel button to check the rest of your channels hope this will solve your problem!
2answers
How do I channel scan for antenna with blackweb remote and a lg tv
Go into the tellys setup menu and select update channels then go to auto and it will find all the local stations.
I have an lg tv model 37LC2DB - EC I lost all my channels and can not auto programme so I did a factory reset now it says not programmed how do I get my digital TVs channels back
Re-program.
lg tv factory reset, not programmed? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Sep 21, 2011 - I performed a factory reset for my lg tv like I was told to do by the ... to get set for digital and now it keeps flashing not programmed anyone know ...
In my lg smart tv showing not programmed how to program ...
nordstromchicago.com/In_my_lg_smart_tv_showing_not_programmed...
My lg smart tv keeps saying its not programed it wont switch on .... And after all is done, then run Error Checking/Chkdsk using the instructions in the link below. How To Run ..... We got a new lg smart tv was up and running now says not programmedwhat to do .... I have tired Auto tuning and Factory resetting. but no luck.
LG TV Signal Diagnostics, factory reset and manual tune ...
? 25:30
https://www.youtube.com/watch?v=IxKcCbjLD4I
Sep 29, 2011 - Uploaded by 1976stuart1976
LG TV Signal Diagnostics, factory reset and manual tune - Post Digital .... one the net ran for a bit and now its telling me im notconnected and I ...
Hi I have bought acoustics solutions tv second hand model LCD26805HD I cannot retune it can anyone please advise? Thank you
You need the (original correct) remote. Alternatively, you can use a programmable remote, but the ''menu'' must also be compatible with the TV. If you cannot ''navigate'' the Menu and Settings with the remote, you are stuck without a solution. // With the remote you enter the menu ''settings'' and then enter ''channel tuning.'' Then set for either ''manual tuning'' or (best bet) set for ''auto-tuning.''
I have inadvertently mistuned in my tv and some programmes are not there now.Please advise how to re-tune my tv as the HD is no longer on it. Thank you.
Simple way to do is automatic tuning.Press Menu, go to Channel set up (Programme), select Auto Tuning. Your available channels will be set up in order of their channel numbers. Later you can shift the channels at desired programme number.
sonsunny
1helpful
2answers
Hello .i have a lg tv which i purchased in 2008 and only watched videos,i now want to watch tv i have tried auto tune and it only finds 3 vhf channels and none digital.it has preview built in but i can not...
if it has freeview built in its usually programmes itself try turning it on and go into the menu and there should be an auto tune function hit that and it should tune up but remember it needs to be connected to an aerial if it still says no signal try moving the aerial, getting a booster for the aerial they usually plug into the mains then into the back of your tv and you plug your aerial into that to boost the frequencey if that doesn't work then you might need to think about getting a new aerial but you can get 1 for under £30
LG model NR CI-14F80FS Moved the TV for an elderly person,using the remote, how do I start the automatic re-tuning [email protected]
By pressing menu botton on remote then chose setup/then channel setup before presssing auto tune or channell auto programm you may choose air or cable option then you can go for channel auto programming and your supposed to be done.
hope that will help you
have a nice day
regards alan
Resetting a sony television to receive digital programs
The retuning process is as follows:
  1. Press the [i+] or MENU button on the remote control to display the DIGITAL INFO menu.
  2. Press the BLUE button to display the MAIN MENU.
  3. Press the UP or DOWN buttons to highlight AUTO TUNING then press the OK button to display the AUTO TUNING MENU.
  4. Press the RED button to start the auto tuning process for all available digital channels.
  5. Wait for the process to complete.
If you wish to CANCEL the auto tuning process whilst it is processing then press the BLUE button at any time.
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
Free view
  1. Press the [i+] button on the remote control to display the DIGITAL INFO menu.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
