Hi
GIGABYTE GA-8ID533
motherboard manual link
https://www.manualslib.com/manual/271289/Gigabyte-Ga-8id533.html?page=2#manual
SOURCE: PCI GA-8ID533 V1.1
there is no PCI lock on any retail boards. But there are IRQ sharings and conflicts. Set IRQ to auto, if not, then manualy and if so, then disable a few things, just to free up some IRQs. All depends on the board, best is to consult the manual for the IRQ sharing table and work with that. (disable one SERIAL, IDE port or USB port if you need an extra IRQ) Also check for onboard equivalent to the card you are adding, disable the onboard part...
SOURCE: motherboard
Hi hamideh, your board can Supports up to 3GB PC100/133 SDR-SDRAM Dual memory module DIMM's
Here is the link to your board.
http://www.giga-byte.com/Products/Motherboard/Products_Spec.aspx?ProductID=1402
Enjoy hamideh...
& please vote for me
SOURCE: i need to knw wat is the video card limit in GA-8ID533 (Rev 1.1)
It supports all 4X AGP cards. The max you can get for 4X is 256MB. Nvidia GeForce series has some nice cards for these specs.
SOURCE: how to reset the bios
As the computer starts up hit the Del key, that will take you into the BIOS utility, once in the BIOS load optimized defaults, this will reset the BIOS configuration.
Failing this just remove the power cord from the back of the computer and take the motherboard battery out for 20 minutes, this will fully reset the BIOS so you will have to input the time and date.
Regards.
