Question about Freezers
The amber light is on on my servis freezer - Freezers
Fridgidaire amber light on
fixed connecting wires.
Mar 11, 2013 | Freezers
The red warning light is flashing after freezer being moved
This will happen until the temperature gets down to an acceptable temperature.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 20, 2012 | Freezers
Flashing red light
red light flashing on servis fridge freezer
Mar 19, 2009 | Freezers
My indesit freezer in on amber light on 1 and it is too cold should the light be showing amber
check to see if you dont have unit on quickfreeze.or possibly the thstat is set to high or control is faulty
Jan 03, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
Servis frostfree fridge freezer
Hi, I had that last year - It was the control board!
Oct 24, 2008 | Freezers
Upright Frigidaire Freezer
The Amber light is the Power 'On' indicator. The Red light is a Temperature Alarm indicator. THe Red light comes on if the freezer compartment rises above 20 degrees F (for example a freezer malfunction or someone left the door open). You also probably have a rocker switch (or two holes that are over a rocker switch) that is in between these two indicators. If you do, that's an audible (loud buzzer) alarm when the red light comes on. The rocker switch is a simple on-off switch to silence the alarm or turn it back on.
Jul 07, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
Servis fridge freezer mo330al lights
Hi there
  • Green = Ready (Power ON)
  • Amber = Super Speed Freeze
  • Red = Warning overheating or fault.
Hope this helps
Thanks J
Jan 04, 2008 | Freezers
Try to unplug the unit to reset the error, but if the error persist please call a qualified technician.
Dec 20, 2007 | Engel Freezer 22 Qt. Fridge/Freezer
What are the lights?
I cannot find any manual or information on the 3 lights. I would assume that the green light means everything is OK, the red means current problem, and the amber means manual defrost is due. Sorry, this is the best I can do. Later.
Aug 24, 2006 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Freezers Logo
Top Freezers Experts
Dennis Boxerman
Marvin
Marvin
Are you a Freezer Expert? Answer questions, earn points and help others
