If the exhaust is smoky turn the needle valve marked with an H in (clockwise) about 1/8 of a turn. If not turn it out 1/8. If the fuel in it is older than a month Dump it out and start with fresh fuel before adjusting the needle valve.
If you need to clean the filter, remove it from the fuel tank and blow compressed air into it, otherwise you may have to do the following:
Sounds like you will need to clean your carburetor
Sometimes you can get by with priming it a few times, and letting it run a few times like that and it will flush the gunk out of the jets, but most of the time you will need to rebuild the carburetor. If the mower is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit, because the diaphragm will get hard and that will cause it to be hard to crank. When you clean your carburetor and remove the jet screws, count the number of turns it takes to seat the jets from their original position. That way when you go to put the jets back in, you know how many turns they were in/out. Please do not forget to rate me, Thanks Good Luck, I hope this helped
The chain saw chain sharpener is an "efco Industries" chain sharpener that was made in Italy. Type # 136 & LR# 36941
have a good day
please rate bama46, thanks
There are no "efco" chain sharpeners at Northern Tool or at efcopower.com. There is a Chinese made grinder with the Northern Tool name on it. It is a lessor quality copy of an Oregon model 511A. It is such a good copy that parts and the manuals are interchangable. The 511A manual can be downloaded here: http://www.oregonchain.com/pdf/accessories/511AManual_3Lang.pdf
Lou --> -->
