SOURCE: setup for coby tv-dvd 1350
I need to download the instruction/manual. Can someone direct me?
Thanks
SOURCE: Toshiba 26AV502U Won't Pick Up Channels
Hi albertogiler,
I am happy to help, you will need to attach a antenna to the tv to pick up OTA over the air signals, depending on your location you may be able to use a set of rabbit ears, I have provided a link to a site that will explain in depth.
http://www.antennaweb.org/aw/welcome.aspx
Let me know if this helps and please rate this solution. lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
SOURCE: no tv signal on my olevia 232-s12
cable or Ant.. ? after the scan if there is no channels found (0 digital, 0 analog) then try with cable or Ant to see if any of them work.. if they still don't pick up any channels and the whole yellow progress line goes across.. then it sounds like the tuner on the tv is bad.. and the tuner is part of the main-board so the whole main-board will have to be exchange or repair.. contact Amergence technology they are a 3rd party repair center that service Olevia TV's and they will be able to give you an idea on the repair cost..
<<< Amergence Technology number is 866-965-3842 >>
SOURCE: i need to know how to reset the tv (olevia model
Go to menu -picture- mode- power up - put it on home setting than all controls should be unlocked I think ur in showroom setting 99% of people who reset there factory settings get this problem
SOURCE: i have an olevia 532 b12 model and no tv channels in list
I have an olevia 532 b12 model. I do have cable at my house, straight to tv , no cable box.. but my tv only says a message ''no channels in list'' on the Turner source option. I Just bought this TV with no manual, What do I do in order to see the channels , to me it seems like the remote is locked. I cant change the time date , nothing ? The DVD playes plays and sounds great,,, Its just the cable TV part
Thanks
