SOURCE: Teac GF-350 CD Shelf System
Firstly double check that the recordable discs you have bear the label "Digital Audio" on them as per the attached picture. Secondly what happens when you go through the finialise procedure in the manual? Do you see the ?FIn--d? display when you select the finialise button? Do you see ?NO TOC? and ?REC? indicators blinking at the next step? Please update the question & let us know if the information given was useful to you - Good Luck!
SOURCE: PIONEER DC-Z92 CASSETTE DECK AMPLIFIER
Is this one of the units that has a ribbon cable ( looks alot like an IDE hard drive cable) that connects all the components together? It also has a squre plastic fan that protrudes slightly from the rear (by about a 16th of an inch)? If so, it's the power module which consists of 2 boards (along the fan housing). You can probably find replacements for about $70, but I wouldn't bother. They quit making new replacements several years ago and any board you get now is just a pull from old stck units.... and they fail about 2 minutes after you put them in. Pioneer knows this but still sells the defective parts.
SOURCE: TEAC DVD Duplicator copies CD but not DVDs
your DVD ROM's lens has became weak.
and it cannot be repaired.
But
if you manage to open the DVD ROM clean the dust in it & it will
start working agaain but be careful remember that no power should be
attached to ROM.
pls rate me
thankyou
SOURCE: need codes for ford radio cassette and cd player
Code for M008589 is 5331
Testimonial: "just a word of thanks your code worked i now have tunes ta again"
SOURCE: How do I get my Teac DC-D2831 CD Shelf system to
I was having the same problem, I read my users manual and found that there is a time button on the front of the unit itself. My husband must have pressed ithe last time he used it. Works fine now.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Teac-GF-450K7-manual/id/23167bh436/t/2/
"ER **" (variable) IS in the manual on page 29 and it recommends power off, wait a minute and power on, which isn
