The fan is running smoothly with no noise but will shutoff every time after 20-25 seconds.
Some have a hole from freezer to fridge make sure its free.
Testimonial: "I checked it visually and it is free."
The most common cause for this condition is a problem with the defrost system. If the refrigerator freezer is cold but the refrigerator is warm, the evaporator fan motor might have failed. ... If the freezer is cold but refrigerator is warm the air damper control might be stuck closed or broken.
Testimonial: "the fan is working every time I plug it for 20 seconds. is it possible that the fan motor has failed? how can I check the damper control? thank you."
SOURCE: 1997 Mazda dies when warm - runs smooth when cool
possibly a bad module------cracked---or???? In any case you may get expansion as engine compartment warms up----module shuts you down. Sometimes really hard to diagnose and just putting in a new module is "spendy"----especially if it turns out not to solve the problem!
SOURCE: my radiator cooling fan keeps on running and it
sounds like a stuck relay, relays can sometimes weld themselves closed
SOURCE: my cooling fan won't stop running whats wrong
the fan control relay is burned closed, replace it
SOURCE: Cooling fans are running for a long time and still
If the fans are running long after the car is shut off, the fan relay is fused together. Unplug the cooling fan relay and get a new one. Don't drive it far without that relay though. Put it back in and drive to your supplier.
