Question about Canon Speedlite 580EX II TTL Flash
My 580EX II,off camera I press the pilot button, the flash fires but stays about a couple of seconds..Is the flashgun faulty or need to reset to factory setting?
SOURCE:
  • 9 Answers
SOURCE: Canon SPEEDLITE 580EX TTL Flash Problem: Flash will not stay in ETTL mode
u can use the H sync button only with the camera set in semiautomatic or manual modes, it dosent work in AUTOmatic modes
Posted on Nov 18, 2007
  • 4 Answers
SOURCE: camera does not fire external flash
Also be certain that the flash is screwed onto the shoe as tightly as possible.
Posted on Feb 28, 2009
ftw1952
  • 10319 Answers
SOURCE: 580ex flash will sporaticaly put out a super bright
The capacitor is going bad. Replace the flash unit
Posted on Jan 14, 2010
  • 261 Answers
SOURCE: reverting to ttl - master flash not firing
Hi Kate,
What camera that you are having problem with those flashes?
Will switching the two have the same problems.
Make sure it is fully pushed forward into hotshoe & locked:-)
Try shooting second current, this will save you the repair costs.
Your exposure compensation was set to zero, but was your flash compensation set at zero?
atdlee@netzero.com
Posted on Jan 18, 2010
  • 173 Answers
SOURCE: How to restore factory settings
To reset the C.Fn settings on the flash just go into C.Fn mode and set each setting to 0.
If there is no C.Fn icon showing, the flash is at it's factory default setting.
Hope this helps :)
Posted on Mar 09, 2011
The flash ratio between a master unit mounted on my Canon 5D Mark II and slave doesn't work properly. A couple of shots are fine but then all of sudden the slave unit fires ar full power, then a few week...
If you had the ATG Gold MG8k Flash Kim X3, then your 430EX II or 580EX II can transforms into wireless radio ATG ETTL II.
If you are using the outdated wireless IR ETTL with a 580EX II as a Master. Then you have to set the Slave (ATG/580EX II/430EX II) body facing close to the Master.
atdlee@netzero.com
May 20, 2014 | Canon Speedlite 580EX II TTL Flash
Canon Speedlite 580ex ii - won't work with camera
Caroline, you should try to set the camera on "M" and the flash in 2nd curtain flash sync.
Or set flash in ATG wireless IR ETTL Slave modes and pop-up the flash on Canon EOS-70D.
Truly,
atdlee@netzero.com
Feb 08, 2014 | Canon SPEEDLITE 580EX TTL Flash
Speedlite 580 pilot light on but flash wont fire
More info needed: Will the flash fire when you push the test button? Have you rest the camera you're using to factory defaults while the flash is mounted on the camera and turned on?
Jan 06, 2014 | Canon Speedlite 580EX II TTL Flash
I have been using my Canon 580ex ii with my Canon 5d mark ii. It will not fire at all now. I also tried my old 420 ex speedlite and it will not fire either. But, they both work on my Canon 40d.
You can actually set the external flash not to fire in the menu settings of your camera. Check there or try mounting the flash on your camera, turn both on and reset your camera to factory default settings through your camera menu settings.
Oct 08, 2012 | Canon Speedlite 580EX II TTL Flash
Canon 580EX II Flash is not firing??
It could be the bad bulb. You need to replace the entire bulb assembly. Canon Speedlite 580EX II MYK Camera Camcorder Repair
Apr 22, 2017 | Canon Cameras
I need a manual for my canon 580ex flashgun
580EX:
http://downloads.canon.com/cpr/software/camera/580EX.pdf
580EX II:
http://downloads.canon.com/cpr/software/camera/Speedlite-580EXII.pdf
Jun 30, 2011 | Canon SPEEDLITE 580EX TTL Flash
580EX speedlite not firing
Does the pilot lamp light up? If so can you fire it manually by pressing on it? If the batteries are low it may simply just be taking a while to charge, the camera will not wait for it to be ready to fire and it may seem to be not working. If your flash can be fired manually however, there may be a problem with the cameras shutter or the hotshoe. You can do a basic check by pressing the star button at the rear of the camera, you should get a pre-flash. If not, there is a problem with the cameras hotshoe which you will need addressed by a service centre. If you get a preflash you can next check the cameras shutter by setting the second curtain to sync with the flash. This can be done via the cameras "Custom Function" menu, c-Fn 15. Set the camera to TV mode and chose a 1 second exposure. Take a shot with the flash attached, if the shutter is working correctly, the flash should fire a pre-flash and then a main flash. If it doesnt, the switch inside the shutter is broken and the shutter needs to be replaced. This is a pretty labour intensive repair and you may consider an upgrade as more economical.
Apr 14, 2009 | Canon SPEEDLITE 580EX TTL Flash
Camera does not fire external flash
Is it in manual or auto modes (camera)Try resetting the camera back to factory defaults as a first step.
Feb 27, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon speed lite 580ex 11
I just got the 580 and had trouble with it blinking all the time, the bounce card was out about a mm and I did not realize it, once that was pushed all the way back--voila.
Jun 30, 2008 | Canon SPEEDLITE 580EX TTL Flash
Canon Speedlite 580EX II TTL Flash Logo
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
