Save your contacts & photos and make a hard reset. In this link "how to" https://www.youtube.com/watch?v=nmpFTgZ3pv0
SOURCE: No voice during calls both incoming and outgoing
Have the audio jack repaired it's not making contact on the connecting plates properly. You ould have a go at this if you are very good with fine electronics
SOURCE: buzzing tone. Can barely hear caller's voice because of the buzz
Two things to look at:
First, check the base station isn't too close to some interfering item of electronic equipment - try moving it to see if the problem diminishes.
Second, unplug the cordless phone and put a traditional corded phone in instead (if you don't have one lying around, it would be a wise investment to get one, otherwise you'll be without a phone service if your power goes out). If the buzz is still there, the problem lies with your line rather than with the phone (and that's the TelCo's problem, not yours).
A.
SOURCE: samsung j600 tone received when text message sent
go to menu > messages > settings > text messages and uncheck delivery report. good luck.
SOURCE: How do I change SMS alert tone on Samsung Tocco Lite mobile
Go to Menu > Settings > Phone profiles > click the two arrows beside Normal (or whichever one you use) > go to the top of the screen and select New Messages > Choose Message Alert Tone > Sounds > choose the file.
SOURCE: Hi, I have a nokia 5233 mobile phone. But whenever
Formatting the memory card is of no help . Remove the battery for 10 minutes and set it back. Now open menu-settings- restore factory settings- key in: 12345.
Now open tones and select the incoming message tone and volume. try this out and it must work or the phone software has some errors and might need reinstallation of the software.
Repeat with the battery out for more time and the memory card taken out.
